2nd Gen R57 Convertible Cable assy broken
Discussion in '2nd Generation: 2007+ R55 through R61' started by Iksnorba, May 18, 2014.
  1. Iksnorba
    Iksnorba New Member
    May 18, 2014
    Fort Lauderdale, Fl
    Greetings all, rookie here...I have a 2005 S convertible and the passenger side cable assy broke. The driver side closes, but the passenger side does not close all the way. It's approx 1/16" open. Is there any way to get this to close + clamp completely so I can drive until I can get the $ to repair? Both dealer and a body shop have been little help. Thanks.
    Welcome to MA! I can't help but someone will be along that can.
  3. rum4
    rum4 Club Coordinator
    4,568
    1,475
    SC
    Welcome to m/a.
  4. Iksnorba
    Iksnorba New Member
    May 18, 2014
    Fort Lauderdale, Fl
    Thanks...once I get past this, should be fun!
  5. rum4
    4,568
    1,475
    SC
    Someone will be along to get you thru this
  6. Dave.0
    Welcome to M/A the FUN Mini site. :Thumbsup:
    Sorry I can't help but someone should be able to help after the weekend.
  7. DryMartini
    DryMartini New Member
    Dec 6, 2012
    1,048
    479
    Welcome!
    Bump for someone who can help.
  8. eMINIparts
    eMINIparts Well-Known Member
    3,751
    1,087
    MINI Parts Advisor
    Bedford NH
    You need to drop the trim pannel , that will give you access to the motor...I believe it is a 4 or 5 mm allen wrench for the motor, You need to push up when you insert the allen wrech , I do not remember which way you turn it to get the top closed. but one will open it the other way will close it.....Hope that helps....:D
  9. Iksnorba
    Iksnorba New Member
    May 18, 2014
    Fort Lauderdale, Fl
    Thanks for the tip. I'll get to work on it this week and let you know. Thanks again.
