Engine Drivetrain 1st Gen Cooper S CAI's
Discussion in 'Tuning and Performance' started by drink8648, May 20, 2013.
  1. drink8648
    drink8648 New Member
    Oct 11, 2010
    Owner / Retail Menswear
    Jamaica Plain, MA
    Can I hear any Pro's or Con's about the Craven CAI. I know it can be a closed or open system but has anybody experienced a difference when closed.
  2. Justa Jim
    I believe Nathan know all about those. :Thumbsup:
    I don't use that type of intake, but seems to me a closed system would give you a cooler intake charge.
  4. wmwny
    4,048
    2,246
    I don't use that kind of intake, either, but the ones I have are closed. And, I agree with what Crashton says. I started with an open one but it seemed to gunk up faster, so I ditched it and got the closed up ones.
  5. Jason Montague
    :cornut: My Margi(08 BRG R56 MCS/JCWm) has had the Alta 'open' CAI for 65kmi now and no problems. :Thumbsup:
  6. ScottinBend
    Define open and closed......do you mean a closed "top"?
  7. Jason Montague
    :cornut: Plug 'Craven or Alta Cold Air Intake' into your search engine and those companies will show you the difference.:Thumbsup:
    I've been using the Craven CAI on my car since the first CAI went on it. Always thought the closed box Craven offers is the way to go. The first generation CAI was good, but the 2nd Generation one shows they listened to what their customers had to say. It's a much better unit. The box top stays on, the finish is nicer and it looks a lot better too.
    Could be many things. I define closed as the box is one unit, not open on the bottom to use the OEM bottom half. Top is also closed with a tight fitting cover. There are only a few closed ones for a 1st Gen MINI. Craven and DDM come to mind.
  9. BlwnAway
    BlwnAway Well-Known Member
    Nov 24, 2011
    474
    290
    Generally means Open or Enclosed
    But I tend to over simplify things. :D
  10. peep
    peep New Member
    Jan 29, 2013
    281
    82
    Central New Jersey
    I was thinking about getting one of these for William. But am now torn on doing an innercooler first.
    What do you all think?
  11. wmwny
    4,048
    2,246
    I did the cai first. I wanted my MC to at least sound like a "sportier" car. When I got my S, I did the same, but then added an intercooler later to give it more oomph.
    The cai was also a lot less expensive than the intercooler.
  12. Jason Montague
    :cornut: More bang for the buck with the intercooler. The intercooler will give your engine much cooler air than a CAI.:Thumbsup:
  13. peep
    peep New Member
    Jan 29, 2013
    281
    82
    Central New Jersey
    Jason -- but you dont get the cool sound, right? and the IC will give it a little more boost....right?
  14. ScottinBend
    Sorry, guess I wasn't real clear. I was asking the OP what he meant by open/closed. just to make sure we were all talking about the same thing.
    The original Alta one sealed against the hood, thus it was a closed system when the hood was closed. The ones that advertise a closed one now simply put a lid on the box w/o having to worry about the rubber seal against the hood.
    As for the IC vs CAI debate......well the CAI will gain power in all situations whereas the IC will save you more power only when the temps rise above what can be handled by the OEM one.
    And remember guys, this is a first gen question.
  15. Jason Montague
    #15 Jason Montague, May 21, 2013
    :cornut: Yes, no change in intake sound with the intercooler but with the intercooler feeding the engine denser air, the engine will put out more power than an other wise identical engine with a smaller less efficient intercooler and just maybe a stronger sounding exhaust note to make up for lack of increased intake note. MINI on peep.:Thumbsup:
  16. drink8648
    Oct 11, 2010
    Jamaica Plain, MA
    Thanks everyone for the feedback. I bought the car with the Mini Madness already in place and as far as I'm concerned it is performing well. I recently cleaned and oiled the filter and I do like the sound it makes. However, I do like the looks of the Craven and the idea that the battery terminal and the ECU getting contained into the box is a good idea. My original question was more about gains because of the closed top. Cooler air and less heat but by how much.
  17. Chili_head
    Chili_head New Member
    Dec 25, 2011
    Why jump to the I/C? High intake temps?
  18. ScottinBend
    No real gains from the top as long as the CAI is open to the cowl area.
  19. kent kanipe
    kent kanipe New Member
    Oct 21, 2010
    79
    17
    Corvallis, Oregon
    OK, someone get me straightened out here. My factory intake was, in my opinion, a cold air intake. Cold air was plumbed in directly from behind the grill and the system was closed to the air filter. I installed the NM high flow intake....the sounds are wonderful...without expecting HP increase. I wondered about under hood heat and then realized the original plumbing feeds cold air to the just below the NM filter. I have no plans to change up anything just now, but seems to me tom foolery is afoot.....
    Kent
  20. ScottinBend
    All of the intakes do indeed have a duct from the grill to the filter, what the CAI's do is allow MORE air from a different (colder?) source.
