1st Gen R53 Cooper S California Compliant Header and CAT??
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by martinb, Feb 9, 2016.
  1. martinb
    martinb New Member
    Feb 1, 2016
    25
    I believe I need a new flex coupling on my 2006 JCW convertible and I just found out that it's an all-in-one unit and the best price I can find one for is from my local shop at $1008.00. Owch!
    Does anyone know of an aftermarket replacement for the factory unit? I'd want to retain all sensors, maybe gain a few HP, and not have it much louder than stock.
    Thanks!
    OEM is the only "header" CARB compliant for Kalifornia.
  4. quikmni
    quikmni Moderator
    Jun 6, 2009
    774
    174
    Aerospace Engineer
    Orcutt, CA
    As Dave O stated, only the OEM manifold/header is legal in CA.
    You might be able to get the header welded to fix the crack.
    If you do not find a used OEM header to replace your header you can probably safety get away with installing an aftermarket manifold/header on a CA registered car as long as it has a good cat converter. If you go with a good header/cat combo such as the Flashpoint ($800) or Milltek ($1300) you should be OK. I have never had a smog inspector look close enough that he could tell that the header had been changed, especially on the Mini where the header is under a heat shield. A good aftermarket header with cat should have no problem passing the the non-visual portion of the smog test.
  5. Canusrufis
    Canusrufis RMW Powered R53
    208
    103
    Winston Salem NC
    ^^^^^^^ thats really depressing. "Like you know" move out of CA depressing.
  6. myles2go
    myles2go Active Member
    May 7, 2012
    589
    223
    collecting a paycheck
    WI
    As mentioned a good header and cat should pass the emissions test, but they're not cheap.
    However, it's hard to believe that there isn't a flex joint available that fits the stock exhaust manifold. A quick search on Summit shows 474 flexible exhaust couplers. You'd think one of them is usable.
  7. 00Mini
    2,227
    ^^^^ +1 on the replacement coupler. like
  8. Dave.0
    If you post a new thread asking if someone has a used Gen 1 OEM header for sale you may get a few hits.
    I sold mine long ago when I got my RMW header, but some people still have them hanging in the garage and they may want to part with them.:idea:
  9. macnagaf
    macnagaf New Member
    Jun 15, 2015
    10
    I have a used oem header hanging around probably right around 140k on it though
  10. ColinGreene
    ColinGreene Well-Known Member
    438
    293
    Orange county Ca
    if you broke a flex joint its likely one of the engine mounts if not more than one is trashed.
  11. 00Mini
    2,227
    Like :Thumbsup:
