Suspension Brakes 1st Gen Caliper covers or paint?
Discussion in 'Tuning and Performance' started by ole97texas, Dec 28, 2011.
  1. ole97texas
    ole97texas New Member
    Jun 29, 2011
    MINIster
    Texarkana, Texas
    Any thoughts on painting calipers verses putting a painted cover over them? For an 04 MCS.
  2. WolfGTI
    WolfGTI Active Member
    May 21, 2009
    387
    217
    NJ
    Paint them.... Covers are for the Pep Boys look.
  3. minimark
  4. Dave.0
    Paint...The plastic covers are for JDM Hondas.
  5. Mr. Jim
  6. Nathan
    Caliper covers will hold in heat, heat is the enemy of brakes.
  7. MaverickGun
    MaverickGun New Member
    Aug 24, 2011
    34
    Wow! Look at that BBK! Vroom vroom vroom It's huuuuu-- wait a second. Something's seriously off here... :skep:
    ^ This is another reason caliper covers aren't a good idea. Here's another vote for paint. Powdercoat might be another option too :Thumbsup:
  8. agranger
    I would expect that covers would impede heat removal by blocking airflow around the calipers... which would be bad for almost any track application.
    It seems funny to degrade performance by mimicing performance products...
    +1 for paint or powdercoating.
  9. MaverickGun
    Aug 24, 2011
    34
    I suppose it really just depends on what you're going for. Sometimes it's more important to park hard then drive hard, but even then a BBK will help you park harder then a caliper cover for sure. At least with paint or powdercoat, you'll have the capability of parking or driving equally well without one affecting the other :)
  10. SNEEEZY - Erika
    1,212
    116
    Female
    +1 for powdercoating!
  11. Firebro17
    Paint 'em or leave 'em OEM. I prefer that look as it looks cleaner over time.
  12. Way Motor Works
    Way Motor Works New Member
    206
    MINI Tuner
    Atlanta
    My personal opinion.
    Paint em, the covers are silly and make you poser.:lol: and cost too much
  13. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    You should look closer at some home caliper paint jobs..You might want to expand on the poser comment. :lol:
    Some should never handle the rattle can, EVER! :lol:
  14. iwashmycar
    iwashmycar Active Member
    Jun 1, 2009
    881
    87
    architecture
    IMO leave them stock. Painting looks nice, but can take a lot of upkeep. Unless you disassemble and powdercoat or something else very durable, you will most likely see some chipping. I would always have to touch up multiple times a year. I suppose a good compromise would be a 'bare metal' color.
  15. Batrugger
    Batrugger New Member
    May 13, 2009
    463
    92
    Soldier
    Hesperia, Ca.
    Powder coat is the best, but you need to remove and disassemble the calipers. Here is a set I had done for my VW:
    Unfortunately you cant disassemble the rear brakes like the front because of the parking brake mechanism. I had the carriers powder coated and then painted calipers. With proper prep the paint will last a long time.
  16. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    Not recomended but can be done
    Dissembled rear R53 caliper prior to powder coating. Required a special cage lock tool for re-assemble. All other parts were thoroughly cleaned and polished.
    There is no kit for the rear yet that I know of, they are still none serviceable calipers?
    Powder-coating is the best looking and is more durable over painting but still can chip.
    Before disassemble of the rear R53 caliper and prep work for powder-coating
    After prep work:
    Here is my MINI front caliper with finished powder-coating.
  17. rum4
    rum4 Club Coordinator
    4,568
    1,475
    SC
    Nitrominis those look good:)
  18. agranger
    I bought my Wilwood front calipers used when a friend upgraded to TSW calipers. They had been used pretty hard, so I did a rebuild and applied a few coats of flat black BBQ Grill paint (high temp). It looks very stealth and doesn't show brake dust at all! After about 2 years of service, I did a quick respray to clean 'em up a tad bit where drips of brake fluid from bleeding had changed the paint surface a bit. They still look great and, honestly, I prefer the finish to gloss powdercoat.
  19. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
  20. Jason Montague
    :cornut: MAN!, every thing on your entire car looks GREAT!:Thumbsup:
