Brakes Wheels 2nd Gen Tires Caliper Torque Value
Discussion in '2nd Generation: 2007+ R55 through R61' started by rtharvey, Jun 4, 2011.
  1. rtharvey
    rtharvey New Member
    Jul 5, 2010
    26
    Summerfield, FL
    Does anyone know the proper torque value for the front caliper mounting bolts on an R56 Justa?
  3. rtharvey
    rtharvey New Member
    Jul 5, 2010
    26
    Summerfield, FL
    Thanks for that link, but the 2nd Gen brakes are different and there is another write-up in the library by Ron Pickett (RonsMinnie) to describe the procedure for 2nd Gen which is very good, less complex than Octane Guy's, but only refers to reinstalling the 16mm bolts without torque requirements.
    Aren't 2nd gen fronts the same as 1st gen JCW without the red paint? That is unless these are JCW's and in that case it would be a Brembro caliper.
    Yes they are the same.
  6. Nathan
    Bentley Manual lists the following for JCW brakes on 1st Gen
    Brake Pad Carrier to to Wheel Hub M12x1.5 110Nm or 81 ft/lb
    Caliper to Brake Pad Carrier 7mm Allen 25-30Nm or 18-22 ft/lb
    It's a shame that almost 5 model years out we still do not have a Bentley Manual. They do have a part # and ISBN # listed with a Coming Soon listing.
    The delay is because they have to keep rewriting the timing chain chapter. :wink:
  8. rtharvey
    rtharvey New Member
    Jul 5, 2010
    26
    Summerfield, FL
    I made a pretty good guess when I re-installed I torqued to 85 ft lbs.
  9. m050120
    m050120 New Member
    Mar 8, 2012
    Nathan-
    Any chance you could post some shots of that page out of the Bentley manual for the JCW brakes on the Gen 1. I have an '09 justa Clubman and just did my brakes using Octaneguy's guide. I was showing my wife how to do it and we got the wheel off and she asked, where's that wire thing. I was shooting from the hip from there. the caliper to brake pad carrier assembly looks like it actually has two fasteners that are tightened against each other that I'm trying to make sure I have properly snugged.
    I think if you go to realoem.com you can find an illustration of the brakes.
    Here is the exploded version of the 1st Gen JCW Brakes.
    The Bentley Manual has a copyright and if I was to scan and post pages they could come after me with a takedown notice.
