2nd Gen R56 R57 R58 Catless down pipe and O2 extender/spacer
Discussion in 'Tuning and Performance' started by MCS02, Oct 27, 2019.
  1. MCS02
    6,322
    I am considering a Catless down pipe for the R58. I know a tune can prevent a check engine light from coming on due to the second O2 sensor, but I already have a RMW tun on the car and unless I have Jan do a new tune I don't want it messed with. Once I do more to the car I may have a new tune done but not for a down pipe.
    Has anyone used a spacer when removing a cat with good results? Or does anyone know of another way of preventing the light from coming on?
    Detroit Tuned has a has a Milltek down pip with a hi flow cat but I think I would like the Catless Milltek. They also sale a Vibrant O2 extension.
    If I get the catless down pip I plan wrapping it and getting a turbo blanket.
    So any thoughts?
    What you do is your business, but why use a catless down pipe? Buy the one with a high flow cat & keep it clean. Having driven behind a MINI without a cat all I can say is they truly stink & throw all kinds of carp out the tail pipe. :Whistling:
    Catted pipe
    Wrap it up
    Yes :)
  3. MCS02
    6,322
    I am concerting it because of the higher flow. But the one with the cat may be as good I don’t know. But if I go catless I can spit fire out my rear end! Like feeding the Helmet jalapeños!:p:D:D
  4. old81
    I would agree with Crashton, go high-flo catted, wrap it, enjoy it. If all you are looking for is more HP, I would have Jan do a suicide tune. :) :)
    I had two of Jan's tunes on my 07, one was insane and drivable and the other was just going to blow my engine due to my driving style. :)
    Wish I had my 07, might buy it back I still own the tune package for it! Might need a reload since the current owner migh have let the dealer update the ecu, sad! :(
  5. Dave.0
    Lee, when Mark owned the Helmet he did everything that was possible for “reliable” power. I am sure he considered the same down pipe mod and the cons outweighed the pros after reviewing with Jan, Colin and others.
    Just saying...... keep it the way it is because its a well modded car that is fast and it’s works.
    • Like Like x 2
    • Agree Agree x 2
  6. MCS02
    6,322
    This is true. I was just looking too squeeze a little more out. I did talk to Jan amount 6 months or so ago about Meth but did not think to ask about the down pipe. The meth would keep it clean and he said I would not have to retune for it.
    I have look at the AME meth system there is a big price difference in it and the Aquamist. But from what I have read Aquamist sounds like its best for the Mini.
  7. minirab
    Lee, did you go with colder plugs after Jan tuned it? He did mine and I still have the stock JCW plugs. Thanks.
  8. MCS02
    6,322
    I am pretty sure I still have the JCW plugs. I have changed them but I put the same ones Mark had in it. I will check tomorrow and let you know.
  9. MCS02
    6,322
    @minirab I pulled a plug it looks like I have the ILZKBR7B8DG. I believe that is the stock JCW.
    Are you planing on going with one colder?
  10. Sully
    Sully Administrator
    Jul 21, 2015
    Software
    30350
    First - don't listen to me... bad influence. Shooting fire sometimes is fun. I remember test driving the GP2 car and it made me giggle. That said, I know there is nothing left in the muffle (was already a catless downpipe).
    Dave agree in many ways. Lee - refer to my first statement. That said, I know you like to work on stuff and make it yours. Its hard to "leave" something alone. I fully understand... if you like to build stuff, hard to leave it alone (says the man who has two engine projects in his garage... lol)
    While I'm no expert in turbo's (still learning)... I do like the Aquamist system. Seems to work well. That said, I need to do a flow test etc as you should do that as part of a maintenance schedule from what I've read.
    • Like Like x 1
    • Agree Agree x 1
  11. MCS02
    6,322
    Another reason I was thinking about this is the car is to damn quiet. I don’t want it real loud. I looked into a new cat back but was told between the turbo and cat it won’t be much different. So a little better flow and a little more sound may be worth it. Mark already deleted the resonator.
    The only thing is the check engine light but from what I have read putting some sort of O2 extender on it will do the trick.
  12. Sully
    Sully Administrator
    Jul 21, 2015
    Software
    30350
    Yea - You can tune that out... I also think I remember reading about some way to bypass (fool it) mechanically. On mine, when I switch to the stock tune, it comes on. Once I flip it to a tune, it goes away.
    This stuff kills all warning lights. ;)
    • Funny Funny x 2
    • Like Like x 1
    • Agree Agree x 1
    • Winner Winner x 1
  14. MCS02
    6,322
    The mechanical what is with O2 sensor extender
  15. Sully
    Sully Administrator
    Jul 21, 2015
    Software
    30350
    From what I understand yes... remember reading about it but never tried it.
    On the VW side of things some folks use an extender in an attempt to kill check engine lights. Works for some so it's worth a shot. Most of them VW guys just end up chasing their tail.
    I hope you have better luck. At least you don't have smog checks. For those that do it's really big problem.
    • Like Like x 2
    • Agree Agree x 1
