2nd Gen R56 Cooper S CC-ID 029
Discussion in '2nd Generation: 2007+ R55 through R61' started by henry727, Aug 19, 2013.
  1. henry727
    henry727 New Member
    Sep 23, 2011
    Hello all. I recently had my timing chain and tensioner replaced at the dealer. My 2007 Mini Cooper S has 72,000 miles. Now the half power Check Engine Light is on above the steering when but there are no warning lights on the center dash display. My code scanner and the one at Advanced Auto do not detect any codes. I was able to get this code by cycling the BC switch:
    How do I fix this and why wont my scanner pick up the code?
    I may be wrong but I'll try this out anyway.
    No code because you have a pending code, the reader you have may not be able to see that but you can when cycle the BC Switch (whatever that is).
    It is, however; saying "Take me to the dealer!", or try a different code reader that offers a deeper layer of reading ability.
    My research is saying CC-ID 029 is a BMW and therefore MINI specific code. Has something to do with the fuel pump, I think, maybe.
    MINI extended the fuel pump warranty on 2007 - 2009 cars to 10 Years or 120K miles. See http://www.motoringalliance.com/forums/cooper-s/4059-r56-high-pressure-fuel-pump-warranty-extension.html#axzz2cTHEvdg2
    Oh and Welcome, thanks for joining Motoring Alliance, the FUN and Friendly MINI Community.
  4. 05r50
    05r50 Well-Known Member
    Dec 4, 2010
    1,269
    696
    I had the same code with a tank of bad gas. Once the gas moved on, so did the code.
  5. rum4
    rum4 Club Coordinator
    4,568
    1,475
    SC
    welcome to m/a
  6. MCS02
    6,278
    Welcome to MA
  7. Agbullet25
    Agbullet25 Member
    Apr 2, 2013
    40
    23
    Central Texas
    How did you pull this code without a proper scan tool?
