Did not see a chart for 2 Gen codes, so are they the same as the ones listed in the library? Yes. The codes are common to both generations Engine runs, idle is a bit rough, but then it normally is. Going to change plugs as I have 41K Scan Gauge says P300 & P302. Randum misfire & misfire cyl #2 When I hit "clear", "Yes", the screen just goes blank. Hit another button and it comes back on. Codes will not clear. Turn car off; insert key fob; press start button once; scan + codes + Clear + yes = gone Any ideas?????? Bought gas in a, sometimes questionable area, even though it was Shell. Down to half a tank so filled up again at regular station. Codes cleared and all is right again. Jim
OK, remembered an old thread from RonsMinnie and got the code cleared. Still need to know if they are the same as 1 Gen, which says "miss-fire". Jim
