Changed my oil for the first time and learned a lesson
Discussion in 'Starting Line - New Member Introductions' started by Blasbo, Apr 5, 2014.
  1. Blasbo
    Blasbo Member
    Jan 8, 2014
    30
    The lesson is "plan ahead". It took two stores to find a filter and three trips to get the right drain plug. Also couldn't find a filter wrench anywhere. Finally borrowed a 36 mm socket and had to spin it with a pipe wrench.
    I got it changed finally and ordered everything I need for next time.
  2. Metalman
    Only a few filter sources to consider....
    MINI OEM
    Mann
    I believe NAPA carries Mann rebranded....
    Others have proven inferior.... Problems with collapsing media... etc...
  3. Minidave
    Yep, I wouldn't use anything but factory filters on my MINI, and it's probably a good idea to buy a spare drain plug, they get stuck and rounded easily - not by you necessarily, but the previous owner(s) and oil changers.
    Don't forget, synthetic oil only in your MINI.....
  4. Blasbo
    Blasbo Member
    Jan 8, 2014
    30
    Thanks for that info. I had to get an STP filter locally, but I ordered an OEM.
  5. Blasbo
    Blasbo Member
    Jan 8, 2014
    30
    Yep, Castrol full synthetic 5-30 and I did order a spare plug.
  6. ZippyNH
    Some vendors offer filter change "kits".... Usually 5 or 6 filters....saves on shipping...and can drop the price per filter down to $6-8 each for OEM/Mann filters if I recall right...
    Some big box stores can charge CRAZY prices for crap filters four our cars....
    They are just filter media...no back drain plugs, etc...and are pretty inexpensive.
  7. Minidave
    My dealer charges $8 bux and change for an OEM filter, right over the parts counter....
    I get 5 quarts of MINI oil and a filter for about $35 including tax.
    Now that I'm out of warranty I still use factory filters but I've switched to Mobil 1, it's 5 qts for $21 at Wally World on sale. 5W30 of course....
  8. MCS02
    6,328
    You can get a oil filter socket on eBay cheep.
    [ame=http://www.ebay.com/itm/New-Schwaben-Oil-Filter-Housing-Socket-OC-03-/390797895335?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ACooper&hash=item5afd5ea6a7&vxp=mtr]New Schwaben Oil Filter Housing Socket OC 03 | eBay[/ame]
    I only use OEM filters.
  9. Dave.0
    Only use OEM filters and use whatever oil you choose in the correct weight as other have said. 5w30
    Welcome to M/A. :Thumbsup:
    I'll be the odd ball here. OEM or Mann filter & Mobil 1 0w40 of course.... :D
    Welcome to M/A & good on ya for changing the oil. :Thumbsup:
  11. Gil-galad
    Gil-galad Club Coordinator
    May 19, 2009
    1,178
    431
    Decorah, IA
    ...then we're the Oddfellows, as that is my recipe. :Thumbsup: Always insisting on the ACEA A3/B3 rated oils.
    Why do I love changing my own oil? I take my time to ensure no dings, scratches, or paint swirls. I use plenty of rags and will not spill a drop on the engine or garage floor. I drain the crankcase completely. I treat the O-ring with gentleness. I make sure the filter cap and drain plug are torqued to their exact specification. I don't under-fill or overfill.
    That sort of TLC isn't always guaranteed from a grease monkey who may just be going through the motions...
  12. vetsvette
    ^^^What he said^^^ Guess there are at least two oddballs here. :wink:
  13. Dave.0
    I am also an oddball with my oil but I just wanted to give basic information. :aureola:
  14. Apok
    Apok New Member
    Jun 15, 2013
    776
    357
    Why 0w40?
  15. vetsvette
    Here's a link.
    What's the right oil for my car?
    For around $24 for a 5 quart jug at WW, you can't beat it. I run Mobil 1 in all of my vehicles except for the HD.
  16. Apok
    Apok New Member
    Jun 15, 2013
    776
    357
    So Mini and Dave.0 say 5w30, but Mobil 1 say 0w40. Is this just a preference? or is there an advantage to doing the 0w40?
  17. vetsvette
    0W40
    Your vehicle has a specific recommendation.
    The company that manufactures your vehicle recommends this Mobil 1 product, or has a special requirement.
    Current Vehicle:
    Year: 2007
    Make: Mini
    Model: Cooper
    Engine Type: 4cyl. 1.6Liter Turbocharged
  18. MCS02
    6,328
    5w30 for me.
  19. ScottinBend
    5W30 for first gen, 0W40 for second.
  20. Apok
    Apok New Member
    Jun 15, 2013
    776
    357
    Thats just odd cause my oil cap and manual says 5w30. Guess Ill put 0w40 in next time.
