1st Gen R53 Cooper S Check engine light help
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Felixy69, Aug 13, 2016.
  1. Felixy69
    Felixy69 New Member
    Aug 2, 2016
    26
    Hi guys
    Got the check engine light and it is pulling two codes
    1126
    0838
    What should I do ??
    Any help would be appreciated !!
    Thank you
  2. DneprDave
    Which year and model MINI do you have?
    If you put that information in your signature you won't have to put it in every post when you ask questions.
  3. Felixy69
    Felixy69 New Member
    Aug 2, 2016
    26
    2006 Cooper s
  4. Felixy69
    Felixy69 New Member
    Aug 2, 2016
    26
    2006 Cooper s
  5. MCS02
    6,317
    1126 is not listed in that link but the Bentley manual says............
    P1126 Throttle position sensor A and B range/performance large error
    I can't find a P0838 in the manual. The link list it as,
    P0838 Four Wheel Drive (4WD) Switch Circuit Low???
    Do you own the one off AWD R53 Getrag made?:biggrin5:
    What is the car doing?
  6. 00Mini
    2,263
    A Bentley manual is your friend when working on a MINI.
  7. Felixy69
    Felixy69 New Member
    Aug 2, 2016
    26
    Funny thing is I don't have one of those AWD mini
    My car is a very regular r52 MCs !!!
  8. Felixy69
    Felixy69 New Member
    Aug 2, 2016
    26
    Thank you for pulling the codes for me, but now what do I do to fix it ?
  9. Felixy69
    Felixy69 New Member
    Aug 2, 2016
    26
    The car is in limp mode, no boost and stalls often plus misfiring
  10. DneprDave
    Take it to a mechanic.
    You will do better if you take it to an independent MINI specialist than a dealer, dealers are too expensive.
  11. Felixy69
    Felixy69 New Member
    Aug 2, 2016
    26
    some say that 1126 is throttle position sensor at fault
    so can i just buy the sensor or do i have to replace the entire throttle body ?
    thanks
