Driving and engine started running rough and the Check Engine Light came on, after 3-4 miles it started running good again.. The next day after a few short trips around town I noticed the light was Off. all seemed ok, no symptoms. I went to AutoZone, there was two codes. P1338 ( Camshaft Position sensor bank 1 open circuit/short to B+) and P0342 (Camshaft position sensor A, circuit low input B1). FYI about 2 years ago I had the Camshaft sensor replaced for a similar code. Well I called the Dealer..... Extended Warranty expired last month. The SA said since it cleared on its own all should be OK. also said it could be from Carbon buildup, Bad Gas, too much oil or serious issues too scary to repeat. Wow!! I mentioned Service Bulletin S1-12-01-10 (NHTSA 10036977) he said this was only related to an S not "justa" mini (non-turbo) He said if it reoccured bring it in for a by the hour charge. Opinions? anyone have a similar issue or advise for me? I only have 41K miles.
What year car? If you paid to have the sensor replaced before it should be covered under MINI's two year warranty on Parts and Labor. They will have a record of it if you don't but it's better to bring your own paperwork showing they did the repair once even if it was under warranty.
Sounds like the part was replaced during the extended warranty period, so the 2 year on parts doesn't come into play.... He will get 2 year warranty when the new one is paid for and installed by the dealer...
The check engine light went out. The dealer said there is no current issue or the light would still be on. Should I worry? Should I wait until it reoccurs? Should I disconnect the the battery to wipe the existing code still in memory? the scanner did not show a date/time stamp.
UPDATE..... Same error reappeared. The Part from my car that was installed at the factory was a Bosch number. the Mini part numbers do cross to/from it. Mini PN: 13-62-7-588-095 $74.00 Bosch PN: 0 232 103 064 $25.75 AutoZone did not have it in stock but got it Overnight for $26.45 total. Replaced it and after starting it the error was still there. I ran a few min, turned it off and started it again the 2nd time and the error went away. Good part on a digital meter checked as: Pin 1 to 2 = open Pin 1 to 3 = 279K ohms Pin 2 to 1 = open Pin 2 to 3 = open Pin 3 to 1 = 230K ohms Pin 3 to 2 = 131K ohms I hope this helps someone else that may get this issue. :cornut:
Glad you got it working but how is it that you have different resistance numbers for the same pins, just by switching the leads? Kind of weird.
