1st Gen R53 Cooper S Check engine light :(
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by DRKadron, Apr 13, 2015.
  1. DRKadron
    DRKadron New Member
    Mar 24, 2015
    9
    9
    Hey very new to minis and this forum. Just got the car in February and today my check engine light came on. In a previous car I owned (non mini ) there was a way to see what code it was throwing without a scanner. Is there any way to do that on an 05 r53? Please help. Can't find any info with searches. Might be searching the wrong thing though. Thanks for any help.
    You will need a code reader of some type. Autozone and other parts stores can often read them. We have a full listing of all the codes for reference. We can also help diagnose the issue with the code.
    Please visit ECU Codes Chart - 1st Generation MINI - Library for the codes.
  3. minintrigue
    minintrigue Active Member
    Sep 30, 2009
    233
    Banker
    Cincinnati, OH
    You can have autozone read them, but that's only a temp reading as they tend to not be specific. You need to get a scanner, or a friend with a scanner.
  4. DRKadron
    DRKadron New Member
    Mar 24, 2015
    9
    9
    Ok thanks. That's what I was afraid of. Just got this car as a daily driver and already having several issues. Love the car other than that.
  5. M1N1
    M1N1 Well-Known Member
    Jan 5, 2014
    726
    329
    Tool and Die Maker
    NW Ohio
    Buy a scanner. You will get more codes.
  6. DRKadron
    DRKadron New Member
    Mar 24, 2015
    9
    9
    Ok what scanner do you recommend? Links work as well I'm not opposed to research.
  7. Savvy
  8. Dave.0
  9. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    The advantage of the Bav Technik reader vs. the Auto Zone readers is that it reads proprietary MINI codes, which are a great majority of the codes that your MINI will store. We sell it as well.
  10. M1N1
    Jan 5, 2014
    726
    329
    Tool and Die Maker
    NW Ohio
    Also buy a Bentley Service Manual. This is an absolute "must have" for your MINI. I have the hardback edition that has a comprehensive section for all of the diagnostic codes.
  11. Zapski
    [Apple Authorized Service Provider of over 20 years Experience]
    You could just boot the Mac into a Windows OS. They can run either operating system natively, no emulation needed. Just restart, and boom, Windows works exactly the same.
    https://support.apple.com/en-us/HT201468
    Of course there are also plenty of cheap used laptops out there, which might be simpler.
    [/Apple Authorized Service Provider of over 20 years Experience]
  12. Dave.0
    Yeah many people have tried that with mixed results. I a sure it was user error. Code=Id10T
    A net book is about $200.00 and that's all I use it for.
  13. Kenny kustom
    Kenny kustom New Member
    Jan 24, 2015
    297
    178
    I gave up long ago trying to run anything diagnostic automotive on my macs.
    Dedicated windows laptop in the garage.
    Only windows based computer I own. Not even allowed in the house. Lol.
  14. Zapski
    In the end, it really probably is much simpler to get a dedicated cheap laptop. But you know, I gotta say that kind of thing, or I'd lose my standing in the Apple Cult hierarchy.
  15. MCS02
    I to am in the Cult!:D
  16. Canusrufis
    Canusrufis RMW Powered R53
    208
    103
    Winston Salem NC
  17. Dave.0
    I have a few Apple products and I like them so I guess I am also in the cult. (iPad, iPhone, iPod)
    Then again when real work and business need to run they run on they run on PC's with Windows OS. Is it better? I did not say that.
    It just what the industries have chosen because Apple is very proprietary with its hardware and software.
  18. Nathan
    I have a few Apple products too and I like them so I guess I am also in the cult. (iPads, iPhone, iPods)
    I'm writing a lot more these days which I can do from anywhere. Being urban a wi-fi signal is pretty much prevalent. Simple tools such as https://draftin.com/ keep the screen clean leaving it easy to write without distraction. A Google Pro acct provides tons of cloud storage, access to the suite of Apps and all kinds of account tools.
    The only thing really keeping me to a Windows based desktop is the screen space I have here. It's so much easier to play with code when you have 3 giant monitors.
    Also have a Windows laptop for the ViPec.
  19. BLKmini808
    BLKmini808 New Member
    Apr 22, 2015
    Honolulu
    Yes there is a way to view codes. With the key in the ignition, but in the off position, press and hold down the odometer reset button with one hand, while holding the button down, switch the key in the ignition to position 1 (first click) with the other hand. The screen will have a number and the word “tEStâ€.
    Here is a list of all the tests on your MINI:
    1.0 Chassis number
    1.1 Kilometer count
    1.2 Parts number
    1.3 Coding-, Diagnostic- and Bus-index
    1.4 Production Date (Calendar week/year)
    1.5 Hard- and Software status
    1.6 Injector status, Cylinder count, Engine factor.
    2.0 Comb system Test
    3.0 Service interval counter
    4.0 Actual fuel consumption in l/100km. eg.0154 = 15,4 liters/100kms.
    4.1 Consumption in liters/100kms.
    5.0 Distance consumption in l/100kms.
    5.1 Actual rest distance with available fuel in Kms.
    6.0 Actual amount of fuel in tank. eg. 123321 =12,3liters left 32,1 liters right
    6.1 Total amount of fuel in tank.
    6.2 Show value of Fuel gauge.
    1= both senders OK, 2= sender failure, 3=ti signal implausible (no reading)
    7.0 Actual coolant temp.
    7.1 Actual outside temp.
    7.2 Actual engine revs.
    7.3 Actual speed
    8.0 Hexadecimal readings of menu 7.0 to 7.3
    9.0 Actual on board voltage (Battery)
    10.0 Land codes
    11.0 Unit codes
    12.0 No function
    13.0 Gong test
    14.0 - 14.4 On board diagnostic codes. eg 000000 = no failures
    15.0 - 18.0 No function
    19.0 On/Off for Test menu.
    20.0 Correction factor for Fuel consumption Formula for correction:
    Shown consumption x 1000 / user defined consumption
    Push the trip reset button to begin the correction. Numbers count up from 0-9, when correct number shows push trip reset button.
    20.1 Sets 10ths. for consumption factor
    20.2 Sets 100ths. and 1000ths. For consumption factor
    20.3 saves the new consumption factor and shows new value
    21.0 Software reset. (Same as disconnecting battery)
