Cleaning wheels
Discussion in 'Detailing' started by Rixter, Jan 13, 2012.
  1. Rixter
    Rixter Well-Known Member
    Jun 14, 2009
    1,230
    79
    Technology Architect
    North of the 49th
    Ok I'm a bit of an OCD when it comes to wheels. I wipe me wheels down very regularly (about every other trip). Obviously there are days I forget (imagine that). :rolleyes:
    Even with all my wiping, I've noticed tiny dark specks imbedded in the wheels from the brake dust, do you think WD40 and/or clay will get rid of them?
    I only have the cheap-o Crown wheels, imagine if I had a nice set how fussy I'd be. :lol:
  2. Rae
    Rae Club Coordinator
    Oct 14, 2010
    907
    Oregon
    WD40 really does work wonders. It gets all the brake/rubber goo off my wheel after track days. I'd try it first, no risk and easier than a clay. Also, waxing them makes them infinitely easier to clean (if you don't already).
  3. Dave.0
  4. Johngo
    Johngo New Member
    1,671
    200
    Art Director
    Sugar Hill, GA
    One of our white-wheeled members swears by the Armor All wheel spray... I have used, also, but my wheels are black and my MINI is usually spotless (except for the MINI dirty butt... Grrr), so I am not the best person to judge!
  5. R35P3CT
    R35P3CT New Member
    Student/Line Service Tech
    Lincoln, NE
    I have used the Armor All spray. Its amazing. keeps my white wheels looking amazing.
  6. Rixter
    Jun 14, 2009
    1,230
    79
    North of the 49th
    Thanks for the tips. I'm with Johngo, my next set of rims will be black :Thumbsup:
  7. Firebro17
    #7 Firebro17, Jan 14, 2012
    I just use a good spray wax on my black (powder coat) wheels, or simply use the tire dressing overspray to gloss 'em up when need be. When they're filthy dirty (seldom) using Mothers car wash liquid soap and warm water works to cut the grime. Otherwise I just wipe 'em down regularly with a damp towel.
    For removing the harsh wheel dust, I use Mothers FX Wheel Cleaner. It seems safe enough on the silver wheels on our 525i and if ya use it regularly, it'll keep the pitting from happening.
    I don't favor the use of anything oily for obvious reasons.
  8. BRG_Paul
    BRG_Paul Active Member
    Nov 20, 2011
    758
    184
    Turbomachinery Engineer
    York, PA
    I'm with Dave, SONAX is outstanding! Best I've ever used.
  9. Firebro17
    I'll try the Sonax and see what I'm missing. Made in Germany, gotta be good stuff I guess.
  10. goaljnky
    3,105
    394
    Mr Clean Magic Eraser.
  11. BThayer23
    Another vote for Sonax. It works wonders. If you have a pressure washer you can really do some serious cleaning.
  12. Rixter
    Jun 14, 2009
    1,230
    79
    North of the 49th
    Seriously?
  13. goaljnky
    3,105
    394
    Actually, yes. Should I not be doing that?
  14. Rixter
    Jun 14, 2009
    1,230
    79
    North of the 49th
    Actually that sounds quite reasonable. I just didn't want to run out and buy a pack if you were pulling my leg. I like the idea of doing something in my garage that doesn't require rinsing off with the hose.
    Good idea
  15. alwzopn
    alwzopn New Member
    Jul 1, 2010
    183
    Isn't Magic Eraser a mild abrasive?
  16. goaljnky
    3,105
    394
    Maybe. They have regular and extra strength. I know the pad will break apart with use, so it is not as if you're using steel wool. Plus it is used on induction cook tops and painted walls, so I think it is mild enough for wheels. The brake dust probably does more damage to the wheel finish than the pad.
  17. BlueMist
    BlueMist New Member
    Feb 2, 2012
    I wouldn't recommend the Mr. Clean pad. There are only a few things you need in your arsenal to maintain a decent looking wheel. First you need some good product. I use either Sonax full effect for really dirty wheels, or P21S gel for just some maintenance. For brushes I would go with the Uber Spoke Brush from Detailers Domain as well as the Swissvax wheel brush. These two should keep your wheels nice and pretty. If you find some crusted on brown spots use some detailing clay and a good clay lube to remove it, then I would recommend sealing them up with any sort of wax or sealant. A wheel specific wax would be ideal, but anything is better than nothing.
  18. Metalman
    I've been looking for this Sonax stuff.... Is it only Internet order? Any local national chains carry it?
  19. Octaneguy
    Octaneguy New Member
    Apr 24, 2009
    579
    31
    Dream job
    Anaheim, CA
    Thumbs up for Sonax Full Effect
    I like the Full Effect wheel cleaner but it's pretty expensive to use. I wouldn't say it's the best wheel cleaner as I've used a lot of them. It's just as effective as the Meguiar's Wheel Brightener I've used for years, but it seems less toxic and a bit safer to use.
    I'm in the process of becoming a Sonax dealer...just about to place my opening order with them, so if anyone is interested..no need to go to Autogeek or other non supporting vendors....you can get them through me as well. I would of course appreciate your support more than any of those bigger retailers would.
    Richard
  20. Metalman
    Thanks Richard, I'll be contacting you. Gotta take inventory on my Prima stuff and see what I might need now that Spring is right around the corner.
