Brakes Wheels 1st Gen Tires Clicking sound from rear (brakes)
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by xalfa, Oct 25, 2010.
  1. xalfa
    xalfa New Member
    Nov 24, 2009
    85
    Hey. I've got a metallic clicking sound coming from the rear. Goes up and down with wheel rpm and is most noticeable at lower speeds. It goes away when I apply brake pressure, even very light. Seems to be getting worse over time.
    Thoughts?
  2. Minidave
    4,592
    Have you or somone else changed the rear pads recently?
    Most likely, the rear pads are not installed correctly. There are some wire clips on the pad that goes next to the piston, those clips slip over the rim of the piston, into the groove.
    + 1 First place I'd look.
  4. ScottinBend
    LOL....didn't I just go thru this very same thing!
    Yep, check the clips on the rear inside pads. Mine came off after bedding in the brakes.
  5. xalfa
    xalfa New Member
    Nov 24, 2009
    85
    Thanks. I'll check the pads. These have about 25k on them, but could be that a clip has come loose.
  6. xalfa
    xalfa New Member
    Nov 24, 2009
    85
    Yup, broken clip on one pad. Since the same guy installed them, no charge to replace it. Jacques at Bay Bridge Motors is the coolest.
  7. Minidave
    4,592
    Ha! Score 1 for the MINI Cooper brain trust!
    Glad it was something simple! :Thumbsup:
  8. andrewstuber
    andrewstuber New Member
    Feb 18, 2011
    12
    I am having a similar problem. However the noise speeds up, when I apply the breaks.
    I did the EBC Sport rotors and Greenstuff pads. Any thoughts?
  9. Minidave
    4,592
    Are you saying that you already checked the rear pads to see if the clips were installed correctly on the piston and you think it's something else?
  10. andrewstuber
    Feb 18, 2011
    12
    I haven't checked the pads...the guy who did the work is trying to tell me it's the cut of the rotors...
    But unlike the original post, the clicking speeds up when the breaks are applied.
  11. BThayer23
    #11 BThayer23, Apr 7, 2011
    It's the pad clips. That or your installer stuck some playing cards in there. :D
  12. andrewstuber
    Feb 18, 2011
    12
    That's exactly how I descried it to him, playing cards...
    But I'll check the clips or make him do it...lol
    The clips loose, would make the clicking faster when reals are being applied?
  13. iwashmycar
    iwashmycar Active Member
    Jun 1, 2009
    881
    87
    architecture
    wheel bearings sound like that when they go, and obviously noises will go with speed. BUT if it stops with brakes it should be the brakes lol
  14. andrewstuber
    Feb 18, 2011
    12
    I really don't think it's a bearing, cause it started after the break change.
  15. Minidave
    4,592
    Did you use slotted rotors on the rear?
    If not, what kind of shape are the rear rotor's in? If they're not worn badly it's the pad clips.
    It's possible to get noise from them during wear-in of the pads, but if you have standard rotors, it's the pad clips.
  16. andrewstuber
    Feb 18, 2011
    12
    I got EBC Slotted sport rotors and free stuff pads-both new.
    I have been driving on them for about 2weeks and have bedded them...
  17. Crashton
    It is either the pads not clipped in correctly of if you have slotted rotors it could be the sound they are making. My slotted rotors are silent.Worth a look...
    I've never heard a wheel bearing make that kind of noise.
  18. agranger
    1,486
    There was an issue at one time with the webspoke wheels causing a clicking noise.
    I did a custom powdercoating of the centers of my Webspokes and when I reassembled (loc-tite and proper torque) the clicking never came back.
  19. andrewstuber
    Feb 18, 2011
    12
    I don't have those rims.
    Also it never happened before the break change...it's got to be bad clips...I'm going to take the rear tire off and see if I can't see anything..(don't have the caliper tool)
  20. Minidave
    4,592
    You shouldn't need the caliper tool, it's only the one pad on each side. I don't know that you can tell just by taking the wheel off - you might.....
    And Andrew, fix your brakes, not your breaks, OK?
