Suspension Clunking suspension noise
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by krushmoto, Jul 29, 2019.
  1. krushmoto
    krushmoto New Member
    May 17, 2015
    When I go over any bumps I'm getting a clunking noise from the rest suspension. Read multiple recommendations that it's the sway bar bushing, replaced w/ urethane and it's still there. Not as bad but still there. Then read I should replace the sway bar links. Nope, it's still clunking.
    Any other suggestions?
    Sent from my moto z3 using Tapatalk
  2. wmwny
    4,048
    2,246
    rear control arms, perhaps. What year is your MINI as well as type?
  3. myles2go
    myles2go Active Member
    May 7, 2012
    589
    223
    collecting a paycheck
    WI
    It doesn't take much play in any of the suspension components to make a large noise. Mine was caused by the nut on top of the coilover shock not being tight enough. You've already checked the most notorious suspects, sway bar bushings and links, I suggest a thorough inspection and tightening of all the components. What does the car have for a suspension setup? Coilovers? Adjustable control arms?
  4. ScottinBend
    Lower control arm bushings......
  5. krushmoto
    May 17, 2015
    It's an 05 with regular suspension. I did swap out to adjustable lower control arms.
