Engine Drivetrain 1st Gen Cooper S Clunks and other strange noises
Discussion in 'Tuning and Performance' started by MCS02, Aug 25, 2016.
  1. MCS02
    First problem. My car makes a clunk when you let off the gas and then accelerate. You have to be above 3 grand. It sounds and feels like a bad motor mount but all my mounts are new and it does not do it all the time. I can not find anything loss. Perhaps a axel?
    The other sound is a slight crunching coming from the rear when the brakes are applied. Agin not all the time and I can not find anything loss.
    last odd sound is the motor. It only does this when it is hot and I have been in slow traffic. When I accelerate and push in the clutch to change gears the motor has a odd sound. Its a lot like if you drive a car with a engine driven fan when the fan clutch locks to give it more cooling. The sound increases and decreases with RPM's. The higher the RPM the louder the sound. I have looked every and can not find the engine driven fan......Ok I did not look for a fan attached to the motor:biggrin5:
    Any ideas? These new hearing aids are great! I hear all sorts of stuff I have not heard before!
    That's easy to fix, turn up your radio.
  3. caseydog
    caseydog Well-Known Member
    Nov 7, 2012
    2,433
    879
    Automotive Photographer
    Dallas
    That could be the problem -- you are hearing things that were there, but you couldn't hear before..
    CD
  4. Guapish_Fliver
    Guapish_Fliver New Member
    May 31, 2016
    272
    Pimpin
    Da wess
    #4 Guapish_Fliver, Aug 25, 2016
    Dang, it sounds like an old pick up then eh?
    If I focus on all the little sounds my car makes I go nuts. Mine makes a symphony of interior noises :rolleyes5:.
    They're not the most buttoned up, quiet vehicles now are they?
    I agree with the radio volume fix. Put some drum n bass on...
    https://youtu.be/ujkc4tOlnRQ
  5. rusty.daily
    rusty.daily New Member
    Aug 8, 2015
    9
    Front lower control arm bushings
  6. MCS02
    I do but thats part of the reason I have hearing ads!:biggrin5: I may add some Alpine 6x9's to the rear to help my 12" sub:ihih:
    Yes my wife keeps saying that! She had told me something was loss but I would say its ok...should have listen to her.:frown2:
    Your are nuts! you drive a MINI:lol:
    Thanks at least someone is helpful. I have Powerflex bushings they are 2 or 3 years old, but I will have a look you never know.
  7. slo_crx1
    slo_crx1 New Member
    Sep 13, 2016
    21
    Photographer
    North East Pennsylvania
    Perhaps the Powerflex bushings need more lubrication, poly tends to squeak and crunch when it starts to dry out.
  8. MCS02
    True. When I do the clutch I will lube them up, but this is a hard hit. I have been so busy I have not been able to even look at my car.
