1st Gen R53 Cooper S Clutch help - street / performance
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Felixy69, Aug 16, 2016.
  1. Felixy69
    Felixy69 New Member
    Aug 2, 2016
    26
    Hi ...problem after problems
    Now clutch is slipping
    Looking for an upgrade but doesn't blow my wallet.
    What do u guys suggest ?????
    Slightly more performance and street driving !
  2. 00Mini
    2,262
    Valeo clutch kit.
  3. Dave.0
    Stay Stock or get the Valeo clutch kit.
    The only really good performance clutch set up is OS Giken and that's about $1,700 without the labor.
    If you not running track events choose one of the above.
  4. MCS02
    6,316
  5. ZippyNH
    Here is the rub...
    The stock or the cheaper stock equivalents VALEO kit is good for most...
    Very few people, even in modded MINI need a performance clutch...
    And the thing is....to get better grip, a performance clutch uses the equivalent of a softer material and a stiffer spring...so they are harder to drive, and wear faster....
    Other issues are done performance designs are loud, or can be glazed, an destroyed easily, by getting glazed, or some oil contamination....
    So stock or stock equivalents is good for most.
  6. Dave.0
    ^^^^ Spot on :Thumbsup:
  7. Felixy69
    Felixy69 New Member
    Aug 2, 2016
    26
  8. caseydog
    caseydog Well-Known Member
    Nov 7, 2012
    2,433
    879
    Automotive Photographer
    Dallas
    Thanks Zippy. I've driven many heavily modded cars with track clutches, and often they were like stiff on/off switches. There is like a quarter inch between engaged and disengaged.
    CD
  9. Felixy69
    Felixy69 New Member
    Aug 2, 2016
    26
    Can you guys also tell me what else I should change along with the clutch to make it hassle free later on ??
  10. MCS02
    6,316
  11. Felixy69
    Felixy69 New Member
    Aug 2, 2016
    26
    Loving this community more and more, thank you guys !!
  12. Dave.0
    It's what we do besides bust each others stones, spend other peoples money and rip on the F56. :lol::Thumbsup::devil:
  13. Canusrufis
    Canusrufis RMW Powered R53
    208
    103
    Winston Salem NC
    Rear main seal while your there. And possibly the shaft seal behind the guide tub.
    Valeo clutch works well. With a lighter feel than OEM it takes getting used too but not more than a few drives.
