2nd Gen R55 Clubman Clutch lifespan?????
Discussion in '2nd Generation: 2007+ R55 through R61' started by Silver Ghost, Nov 8, 2011.
  1. Silver Ghost
    Silver Ghost New Member
    Jun 9, 2010
    6
    Central Jersey Shore
    I now have over 75K (mostly highway) miles on the 'Ghost'. I have started to wonder about how much more time I might have on my clutch. I have seen postings about those who have replaced clutches at 35K miles and less (due to defects or misuse), but I haven't noticed any info on average or high mileage clutch life. Anyone out there have any info?:confused:
  2. CHKMINI
    I have 75k on my 09 as well, mostly highway miles. Using my previous 04 as a reference, I had 106k on it with the original clutch.
  3. jcauseyfd
    jcauseyfd New Member
    May 25, 2009
    201
    31
    Graham, NC
    I'm at 94k on my '08 and still motoring along on the original clutch.
  4. Silver Ghost
    Jun 9, 2010
    6
    Thanks for the feedback. I hope I do at least as well as both of you have.:D
  5. goaljnky
    3,105
    394
    I had 49,876 miles on my clutch in my '05 'vert. I still remember the day it let go. I believe it was on lap 4 of the 3rd session at Streets of Willow. :biggrin5:
  6. KittyMini
    KittyMini Club Coordinator
    1,183
    I have about 25K on the car, and my flywheel rattles.
    Just counting down till implosion :prrr:
  7. agranger
    The clutch in my R53 '06 was replaced about 1000 miles before the warranty expired... it was making a small creaking noise when I lifted off of the clutch (1st inch from the floor). Since the warranty was about to expire, I dropped by the dealership and a tech stepped in, pressed the clutch once and said "yep... you just got a new clutch!".
    I'm at 72k miles now... hoping that it was a factory defect!
  8. AliceCooper
    AliceCooper Club Coordinator
    Mar 13, 2010
    643
    123
    CT Technologist
    South Florida
    I think its time for one of those famous "How to" step by step replacemnet clutch write ups by the one and only " Agranger" :D:Thumbsup:
  9. agranger
    I'd love to... who wants to show me how?
  10. YeloMini
    YeloMini Member
    Jul 7, 2009
    234
    Only 23k on my MCS with no clutch problems. My daily driver is a 5 speed manual Sentra, 250k on the original clutch and still going strong.
  11. Dave.0
    05 very modded MCS with 70 k on the stock clutch.
  12. Ofioliti
    Ofioliti New Member
    35
    Professor
    ... always curious
    More than 80K miles on my original '04!
  13. lotsie
    stagehand/part time detailer
    Right here
    Pushing 115000 on my 03. Our 08 Clubman clutch blew to pieces at around 25000, changed under warranty.
    Mark
  14. grodenglaive
    grodenglaive New Member
    Apr 3, 2010
    313
    68
    Ottawa, Ontario
    118,000 km or 73,000 miles so far so good.
  15. KittyMini
    1,183
    Ugh, nice :mad2:
  16. Way Motor Works
    Way Motor Works New Member
    206
    MINI Tuner
    Atlanta
    I find the biggest factor in clutch life to be driver. Even on my racecar which gets abused I haven't worn out the clutch. But in my justa Cooper I've loaned out to customers the clutch only lasted a year:confused5:
    The other factor I see aftermarket clutches. I'd say 80% of aftermarket clutches are junk and no good for street use. When used on the street many of them bite the dust way too early.
  17. agranger
    Any recommendations for non-junk non-OEM clutches? I've had numerous manual transmissions over the years... well over 150k without ever replacing a clutch and the one in my '06 MCS died in 40k miles. If it goes again soon, I'd rather try something else a bit more heavy-duty.
  18. Belhaven
    Belhaven Active Member
    Jun 2, 2009
    109
    40
    at 115k miles on my '06 and its original clutch.
  19. Metalman
    I find this somewhat interesting and or strange.....
    The 09 factory JCW comes with a 228mm (8.976") diameter clutch.
    The 09 "S" comes with a 235mm (9.25") diameter clutch.
    And they each have a different throw-out bearing listed.
    All per Realoem......
    So would the assumption be correct that the JCW uses a lighter clutch / flywheel assembly? I wonder how the clutch "life" expectancy plays into these differences, as we all report our clutch mileages?
  20. AXO
    AXO New Member
    Nov 25, 2010
    91
    Wellington, Florida
    I just replaced my clutch and Flywheel at 46,000 miles.
