Engine Drivetrain 1st Gen Cooper S Clutch Options
Discussion in 'Tuning and Performance' started by MINIPucker, Feb 1, 2011.
  1. MINIPucker
    MINIPucker New Member
    32
    Other than a significant difference in price and who make them, what is the main significance between the OS Giken and Valeo clutches that I've seen offered?
    This will not be used in a track car, doesn't do autocross or participate in any DE's or anything like that. It's more of a daily driver that will do spirited drives every so often and might even get to see the Dragon a time or two if I am lucky enough to be able to make it there again.
    I'm looking for something that will offer good quality components, as good if not better performance over OEM and something that I'm not necessarily going to have to put in a new one for quite some time.
    Thoughts, opinions? I've not had to put a clutch as of yet in any of the 3 MINI's that I've owned so this will be a first so I want to put something in that is going to serve me for hopefully the remaining life of this MINI.
  2. Jason Montague
    :popcorn::popcorn::popcorn:
    Me Too!
  3. k-huevo
    k-huevo Club Coordinator
    159
    Pipe Creek, Texas
    #3 k-huevo, Feb 2, 2011
    The dual mass OEM replacement made by Valeo has an organic disk compound just like OEM, in fact the OEM disk and pressure plate are made by Valeo. OS Giken's clutch disk has a metallic friction material. I do not know if Valeo's pressure plate and flywheel have been case hardened or received any other treatments (no coating for sure), but OS Giken's components have been chemically heat treated, and materials are high quality alloyed steels. There are significant differences in how the two kits are constructed, free floating pressure plate in the STR OS, pressure plate attached to the cover on the Valeo; aluminum cover on the OS, stamped steel on the Valeo.
    For the usage you have described, and no mention of increased power levels, the Valeo is better suited for you. However, no clutch lasts forever, and "better performance" can be subjective when the environment is street only. I've installed and driven both kits, pedal feel is similar, click over is short & crisp for the OS, engagement is relaxed for the Valeo, the OS requires deft use of both feet to launch smoothly from a stop, but launching and backing up with the Valeo is a piece of cake. The OS STR makes metal ringing noises at idle, the Valeo has a muted rattle. One can become used to the OS STR's characteristics over time.
    There is a new OS Giken model on the horizon designed to behave more civilly on the street, I just can't provide first hand experience with it.
  4. Jason Montague
    :Thumbsup:Thanks Keith.Good enough for me.
  5. k-huevo
    159
    Pipe Creek, Texas
    Another difference is the clutch release bearing. Valeo's release bearing housing is plastic and stamped steel, OS Giken is all steel. The OS STR release bearing is the same one used on very high horsepower, high revving engines, it is very long lived, the Valeo's (same as OEM) has been known to fail early.
    Below are comparison photos of a stock clutch release bearing for an R56 (Valeo) and OS Giken. The stock R53 release bearing is larger than the R56, so these photos are not size accurate for R53 comparisons, and the OS release bearing has a different release arm mounting method on the R53 version; it is representative for materials.
    OS Giken R53 clutch release bearing below.
  6. MINIPucker
    32
    Basically the only mods that I have right now are a CAI and soon will have an exhaust installed, but that is all. Not sure that I will do a pulley yet or not. I know they don't last forever; I'm just looking for something that will last at least another 4-5 years. I'm definitely looking for something that is easy to use and doesn't require a lot of extra pressure on the pedal since my wife will on occasion drive this MINI.
    I am also making an assumption (since this is an area that I am not as knowledgeable about) that since I have been told that the throw out bearing is going that while it is all opened up I should replace the clutch at the same time because it's all going to be open anyway (maybe someone can tell me whether this is true or not).
    All I know right now is that when I am at a standstill and I put it in neutral and take my foot off the clutch, I hear a ticking sound. What struck me as a little odd is that if I am on an incline with the front of the car pointed down, then the ticking isn't as obvious, but on flat ground it is noticeable.
    I know diagnosis by words is not very beneficial without someone actually looking/listening/driving the car, but it might give me ideas as to what might be potential areas of where the problem could actually be.
    The ticking may be the dual mass flywheel.
    If you are in there to replace the throw out bearing it makes sense to replace the clutch. The level of work is the same and it's no small feat. Not a DIY Day job at the next MM.org DIY Day.
    Since you picked up those two flywheels from me, I'd use the OEM one if I was you. The lighter one I gave you will rattle and be a little harder to drive from light to light.
  8. MINIPucker
    32
    I had no designs on trying to attempt this myself. From what I have heard from many people including yourself, it is quite a task and if you don't know what all you are doing then it becomes even more of a beast.
    Thanks for the advice on the 2 flywheels that you gave me. Knowing that the labor portion of this is probably going to be the most expensive of this whole equation, cost reductions anywhere I can get them is going to be very helpful.
  9. k-huevo
    159
    Pipe Creek, Texas
    Making a prediction of how long a clutch will last on the street is not possible. I have a customer I told the demise of his OE clutch was eminent, 30k miles ago :D. Now at 150k miles it sounds worse, but hasn't failed yet.
    Much depends on your ability to absorb replacement cost, if the OE clutch and flywheel are healthy, the release bearing isn't, and spending an extra $500 for a clutch kit means no heat this week, I'd take heat this week.
    You're right about long distance diagnosis, more details are needed.
  10. Rixter
    Rixter Well-Known Member
    Jun 14, 2009
    1,230
    79
    Technology Architect
    North of the 49th
  11. terry
    terry New Member
    Mar 6, 2011
    Throw out bearings
    Keith,
    Late night research -- thanks for being out here for us -- I'm in the midst of clutch flywheel replacement ( 04 MCS w/85K) -- I will choose OEM style clutch and DM flywheel -- can I use the OS release bearing? OEM bearing failure is what started my trip down this road -- would like to avoid repeating, if possible, while staying cost effective with the remainder of the parts.
    Thanks so much!!
  12. davavd
    davavd Club Coordinator
    6
    Architect
    Covington, La
    I have the ticking sound MINIPucker mentions in post #6. It's been there quite a while, so I have kind of been preparing myself for a possible clutch replacement. My use of the car is about the same as MINIPuckers, so (since I missed something somewhere), why not oem?
  13. Michigan Mini
    Michigan Mini New Member
    Jul 20, 2010
    Health Care
    Lathrup Village, MI
    I replaced my OEM after the T/O bearing disintegrated with the Valeo single mass unit. Ir has a more robust bearing and is less than $500. I've had mine in for almost a year with no issues. Just my ¢2.
    Motor On!
    Chris
  14. k-huevo
    159
    Pipe Creek, Texas
    I'm sorry I missed this question terry. The OS release bearing is only compatible with OS Giken clutch kits.
    It is the same release bearing as OEM.
  15. 00zero
    00zero New Member
    Oct 2, 2009
    92
    Pittsburgh. Pa
    #15 00zero, Aug 30, 2011
    Any experience with the ACT Clutch flywheel combo?
    I want something for a daily driver that would do away with the notorious wear items (throwout bearing and dual mass) and could hold more power if i see a need for it in the future :biggrin5: but i don't want to drop OS giken money on my dd.
    What can the Vealo single mass hold HP wise?
    What is the driveablility of the ACT? (i live in pittsburgh do steep hills and traffic are a regular occurrence.)
    The act throwout bearing is all metal in the images i wonder if it is actually an upgrade? it is available for $50. Maby, that plus a Vealo kit would suffuse.
    Thanks,
    Jonathan
  16. dchang0
    dchang0 New Member
    Mar 8, 2012
    #16 dchang0, Mar 8, 2012
    I wondered about the ACT too, and it is not an all metal throwout / release bearing.
    ACT was very helpful and answered all my questions. Here's a run-down of what I found:
    1) Their Mini Cooper clutch kits are designed to work with OEM components, including the OEM throwout bearing and throwout bearing guide. This means that you can mix-and-match ACT parts with the OEM parts, for the most part (some ACT clutches do require an ACT flywheel).
    2) They include an OEM throwout bearing "as a convenience to the purchaser" with their clutch kits and do not manufacture the throwout bearing themselves. In this case, the part number in question is RB131.
    3) The representative who answered my questions went back to the warehouse and physically inspected an RB131 and confirmed that it is partially plastic and not all metal, which supports ACT's claim that it is an OEM part (either Valeo or LuK, from what I understand).
    Soooo, for those of us with OEM R53/R52 throwout bearings that failed prematurely, ACT doesn't currently offer us a longer-lived solution. That said, their clutches seem to be preferred by many Mini owners over the Clutch Master clutches, and they do offer a nice StreetLite single-mass flywheel which should neatly solve the "Chewbacca moan" sound that glazed OEM dual-mass flywheels emit.
    I personally plan on getting the ACT HDSS clutch kit with 600315 StreetLite lightened steel single-mass flywheel. This combo has been tried and reported on by a handful of Mini owners. Most really like the setup but report some light to moderate chatter, with only one or two reports of very loud chatter, and in those cases, it sounds as if something was clearly wrong with their installations.
  17. MINIZilla
    MINIZilla Member
    Dec 24, 2009
    47
    FINALLY, someone nicely explained the issue I'm hearing from my 2006 R52S with only ~50k on it. Please explain: is a glazed OEM dual-mass flywheel a fatal condition? Can you replace the flywheel with less effort than replacing the entire clutch setup, or is that an example of "you might as well replace the clutch while you're..."? I'm trying to learn all I can about this, including the efficiency/fiscal prudence of installing the LSD while it's in for clutch work.
    Cheers.
  18. Nathan
    If you are in there...
    ...you might as well replace the clutch and install the LSD. It pretty much all has to come apart anyway.
  19. MINIZilla
    MINIZilla Member
    Dec 24, 2009
    47
    Is a glazed flywheel immediately fatal, imminently fatal or live-with-it-until-you-have-major-clutch-work?
    Thanks.
  20. BThayer23
    I've been living with mine for 60k+ miles. It went away after a while, and now it only comes back on the occasional cold morning.
