1st Gen R53 Cooper S Cold start idle, any reason to use an AFR gauge?
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Canusrufis, Oct 23, 2014.
  1. Canusrufis
    Canusrufis RMW Powered R53
    210
    107
    Winston Salem NC
    Background: my 05 MCS is starting to have cold start idle symptoms. Since the weather has changed (colder) the cold start stuttering in AM isn't as bad as summer -- summer fuel mix(?). I've researched and checked most everything mentioned on MA except replacing the fuel filter. Puzzling really. :confused5: To recap that experience: anytime the motor is cold, starts up fine but as is settles to idle below 1k the motor stumbles ever so slightly. If I blip the pedal it recovers fine. Then once warmed up she runs like a champ. Even at stop lights. no codes thrown so far.
    It feels like the initial cold start fuel pressure or AF isn't right. I rescued this last november off a used lot in GA. It had no history. Not sure if it was tuned and at idle that tune is off (just an idea). I'm in winston so may give Chris Sneed a call.
    Question: My Q on AFR gauge is that could tell me if the AFR is too lean at start. But might be talking out my arse there -- MA feedback would be helpful :D thoughts?
    Thanks.
    So I may be no help on this one. I don't know how old these parts are but have you tried new plugs and plug wires. Also make sure and use 93 octane. Because you don't know the history of the car I would add some fuel treatment to a few tanks, like SeaFome (we all know thats the best right:D) or what ever your favorite is.
    I know now that I have a few miles behind me I stumble ever so slightly too. Coffee helps:D
  3. Canusrufis
    210
    107
    Winston Salem NC
    All comments are helpful -- even Dave.o's comments.
    I've always run an additive called FP60 through my vehicles. Have a 98 saab 900NG with 280k miles running like a charm; original drive train. I R&R the plugs and wires when purchased ~78k miles (90k now). When I pulled the plugs last month they looked normal, torqued to spec. #4 had a little bit more darker brown on it than the others but still looked ok to me.
    yea coffee with age is best. once you go bolder you never go back
    Have you checked the coil? The connector for number 3 often gets ugly. Might want to take a gander.
  5. Canusrufis
    210
    107
    Winston Salem NC
    Check. It's good. No corrosion.
  6. Canusrufis
    210
    107
    Winston Salem NC
    EML P1498 code
    and like that it happens... Fault code P1498, unmetered air after compressor - or at least what I can find on MA. It pop'd during warm up this AM. I'll do more investigation this weekend; inlet duct assembly, MAP pipes,etc..
    I'll post any findings/solutions/beer selections...
    Check the boots on the supercharger. They old? They Alta?
    OEM work best for this use. I've tossed lots of money down the drain thinking I could do better than OEM boots.
  8. Canusrufis
    210
    107
    Winston Salem NC
    Discovery this weekend - hopefully solved the problem
    Thanks Nat. Good call. I pulled the IC and it had silicone boots (came with the car, not alta); silicon boot on SC output side was stiff and probably leaking. I noticed the "gutter" in the OEMs that the silicone didn't have which, once oil accumulated on the bottom, was probably the catalyst for the leak (guess). Anyway found some OEM boots locally and they seem to seal much better. Also, noticed a boost tube to a sender I hadn't noticed before hooked up the SC via a T-connector. Pulled that out of the equation connecting the OEM set up.
    I'll drive it for a week and see if that resolves the code and cold start.
    Thanks guys for the help. :Thumbsup:
  9. Canusrufis
    210
    107
    Winston Salem NC
    #9 Canusrufis, May 10, 2015
    Must be something with summer mix that aggravates this problem as its back - P1498. Had zero problems all winter. Anyway feedback from others on the following:
    I still can't find any vacuum leaks so turned my attention to MAP sensors. I did find something but not certain its my culprit or even an issue.
    I back probed both sensors with the following results:
    TMAP
    Pins 1/2/3 /4
    KOEO: 0.0V / 1.78V / 4.99V / 1.87V
    Idle: 0.0V / 1.62V / 5.0V / 0.88V
    MAP (near thermostat)
    Pins 1/2/ 3/ 4
    KOEO: 0.0V / no connect / 4.9V / 3.9V
    Idle: 0.0V / no connect / 5.02V / 1.78V
    According to Bentley Pin 2 on TMAP should read @60F 3.9V (KOEO) and 1.25V (Idle, ambient and operating temp). Could this be my issue?? :fingerscrossed: Would appreciate a confirmation before ordering one.
  10. Nathan
    MAP sensors can be considered a maintenance item. It would be a good idea to replace them on general principle.
  11. Dave.0
    Yes they could be your problem but also check your timing chain tensioner is not sticking or your timing chain guides my need replacing. Cheap maintenance and absolutely worth doing.
  12. Canusrufis
    210
    107
    Winston Salem NC
    Thanks Nat and Dave0. I'll look into both -- I'm at 96k so timing chain guides are due.
    I'll update again ltr
