1st Gen 100K+ Compression Test Results
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by jimz68, Oct 13, 2010.
  1. jimz68
    jimz68 New Member
    May 11, 2009
    16
    Turned over 209,000 miles last week on my 04MCS, and decided to do a compression test.
    #1 143 Lbs
    #2 140 Lbs
    #3 133 Lbs
    #4 143 Lbs
    Bentley manual shows a range of 131Lbs to 196 Lbs.
    Soooo.....time to ponder the options.
    Oh! Still on the original supercharger,too! Have had a 15% pulley on for about 185,000.
  2. Onasled Racing
    Onasled Racing New Member
    Jul 19, 2010
    172
    You warmed up the motor prior to this test?
  3. jimz68
    jimz68 New Member
    May 11, 2009
    16
    Yes. It had sat just long enough to get the GRS IC off and the plugs out.
  4. Minidave
    Nothing wrong with that compression - the important thing is that it's fairly even across the board and well within spec. #3 is a little low, but not horribly so.....could just be a tight valve that needs adjusting. (Or are those hydraulic in 2004?)
    I say drive her another 100K and check it again! :Thumbsup:
  5. k-huevo
    k-huevo Club Coordinator
    159
    Pipe Creek, Texas
    You're down somewhat. Did you perform a wet test afterward? Between a wet test comparison and leak down test you'll know if it's time for headwork, rings or both.
  6. C.I.
    C.I. New Member
    Jun 19, 2012
    26
    question
    while I am going to google it, what's a wet test? I have 125K on my R53 and had similar numbers and range, so pleased there. This may be a more general question-- I feel I am not getting the HP I once did. Several mods under the bonnet (CAI, 17% supercharger pulley, and air diverter for supercharger). Routine oil changes and filter cleaning, plugs and wires-- keep it in top running condition. Just wondering if valves and/or even rings needs work. Knowing this is all vague, any ideas? Thank you, and I will keep checking around this thread. C.I.
  7. Jason Montague
    :cornut: This thread is 2 1/2 yrs old so you should probably PM k-huevo to be assured of getting an answer and/or drawing his attention back to this thread:Thumbsup:
  8. C.I.
    C.I. New Member
    Jun 19, 2012
    26
    Thank you, Jason. New to forums and will be mindful of post dates, Chris
  9. Nathan
    A wet compression test is used to indicate if low cylinder pressures are caused by worn piston rings only. The test is done exactly the same as the “dry” test, however a small amount of engine oil (about 1-2 teaspoons) is added into the cylinder to create temporarily seal (to prevent possible blow-by). If compression rises significantly afterwords, then worn piston rings are the culprit.
