1st Gen R53 Cooper S Concern concern concerns
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Razone23, Jun 14, 2015.
  1. Razone23
    Razone23 Active Member
    Nov 3, 2013
    175
    27
    technical support
    nothern CT
    So while driving today and listening to music. During a loss of signal I heard a strange noise. Pulled over and found my RR lower link was snapped and not hanging but onto each end. And my LR wheel was totally lose. Wheel hub shot. But it gets worse both rear tires that have less than 3 months gone. Both in the inside. Don't understand what that's about, other than alignment. Previously never felt anything odd.,or smell of tire wearing. So questions
    1. Should I replace both rear hubs and is there a kit part number.
    2. Lower link suggestions for replacement OEM or who
    3. Where else do I have to look in order to avoid tire wear.
  3. MCS02
    What Dave said. I have the Helix adj. control arms and like them.
  4. ZippyNH
    Northern CT.....any chance within a short hop up to see Pete at Greasysgarage in Worcester Mass?
    Getting somebody too look things over might be a good idea if things have gotten so bad, unnoticed, till now....
    They are getting busy with MOT coming up, but might be worth getting them too take a look....
  5. Razone23
    Nov 3, 2013
    175
    27
    technical support
    nothern CT
    Thanks guys ordered tires and all else needed then it's off to Worcester. Only 30 minutes away.
  6. fishmonger
    fishmonger Well-Known Member
    May 13, 2015
    984
    769
    Madison, WI
    extreme tire wear on inside is most likely due to poor alignment - camber and toe set to extreme values. Possibly because something was gradually breaking and out of spec before it failed completely.
  7. quikmni
    quikmni Moderator
    Jun 6, 2009
    774
    174
    Aerospace Engineer
    Orcutt, CA
    With the link broken your alignment would go way off and the tire will wear very quickly. I am a little confused because you stated your RR link was broken but your LR wheel was loose. Maybe just a typo and your RR wheel was loose. In any case, it sounds like both tires were worn. Negative camber will wear the inside of the tire and too much toe will increase the wear rate. If you car is lowered, the camber goes pretty far negative which will cause wear if the camber is not adjusted back to a normal range.
