1st Gen R52 Cooper Convertible Convertible problems
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by allan1949, Feb 19, 2014.
  1. allan1949
    allan1949 New Member
    Feb 19, 2014
    I have a 2007 Mini Cooper, convertible. Last winter the convertible top did not open beyond the sun roof position. I fooled around with it for several months with no success and eventually took it to a garage. The garage called me several hours later and reported that it had worked perfectly for them, without any work. It continued to work perfectly for me until last night (I haven't used it for several months because of cool weather) when it did the same thing - opens the sun roof but will not open to the complete down position. I would call the garage but was assured they did not find any problem since it was working when they first looked at. Has anyone else experienced this sort of problem?
    Thanks for the help. This is my first post.
    Allan1949
    Sorry I can't help, but welcome to MA! Someone will be along that can help.
  3. eMINIparts
    eMINIparts Well-Known Member
    3,751
    1,087
    MINI Parts Advisor
    Bedford NH
    Check the parcel shelf make sure it is seated correctly....There is a switch where the shelf sits if it is moved or out of place the top will NOT open all the way...Sometimes it gets knocked out of position ....I would check this first...:smilewinkgrin:
  4. patchelect
    patchelect New Member
    Oct 25, 2013
    98
    31
    Currently still working in electric motors sales a
    Patchogue, NY/Dalton Ma
    Unfortunately I seem to recall seeing this type of problem posted by others, but cannot remember what the fix was. The original post was within the last 4 months, possibly in the convertible top section.
  5. rkw
    rkw Well-Known Member
    443
    The rear shelf in the luggage compartment presses on an interlock switch that allows the top to open beyond sunroof position. The switch is on the left side. Make sure that the rear shelf is completely down and secured.
    The "loading aid" levers should be completely down. I would venture a guess that your left side lever is in the up position.
  6. Friskie
    Friskie Well-Known Member
    Jul 20, 2009
    1,650
    1,333
    Highly motivated retiree
    In the here and now, for now.
    If it's been several months since you had cycled the top did you forget that you have to run the sun roof back, release the switch then re-press the switch to continue running the top back? it's a two step process. Only other thing would be the little pushbutton switch under the foot on the left rear corner of the shelf as previously mentioned or one of the release levers is not latched.
  8. eMINIparts
    3,751
    1,087
    MINI Parts Advisor
    Bedford NH
    Forgot my Welcome
    Welcome to the coolest MINI forum on the net..............:cool:
  9. Friskie
    Jul 20, 2009
    1,650
    1,333
    It is a cool forum but you'd better bring along a cast iron sense of humor. :biggrin5:
  10. rum4
    rum4 Club Coordinator
    4,568
    1,475
    SC
    welcome to m/a
  11. allan1949
    Feb 19, 2014
    Thanks for the suggestions. I will check the parcel shelf and the switch.
  12. allan1949
    Feb 19, 2014
    It was as suggested, the button under the parcel shelf was not engaged. I fixed it thanks to your comments.:D
  13. Friskie
    Jul 20, 2009
    1,650
    1,333
    OK, problem solved, now pull up a stump and sit a while. The fool jug will get passed around shortly.
  14. Dave.0
    YAY! :biggrin5: Now Topless season is around the corner. :Thumbsup:
  15. Angib
    On a first generation car, you have only ordinary instruments. If it was second generation with visual boost, you would think it would display a message to say "is the parcel shelf down?", as it seems to catch out nearly every convertible owner at some time.
  16. jiminni
    jiminni Well-Known Member
    262
    Ca.
    Already here :cornut:
  17. patchelect
    Oct 25, 2013
    98
    31
    Can the parcel shelf be removed and the switches jumped out? I really cannot see a practical use for it and since it only causes problems from time to time and means I have to carry my mini spare in the back seat when it's down I though about just removing it altogether.
  18. goaljnky
    3,105
    394
    Actually the shelf is there to support the top when in down position. Otherwise it would collapse into the open compartment.
  19. Friskie
    Jul 20, 2009
    1,650
    1,333
    ...and very much likely to break the glass for an incredibly expensive replacement cost
  20. patchelect
    Oct 25, 2013
    98
    31
