2nd Gen R56 Cooper S Coolant leak under HPFP/vacuum pump?
Discussion in '2nd Generation: 2007+ R55 through R61' started by Systemlord, Sep 8, 2013.
  1. Systemlord
    Systemlord New Member
    Mar 28, 2013
    311
    67
    #1 Systemlord, Sep 8, 2013
    First of all I want to apologize for creating so many threads lately, but it seems I'm having a lot of problems lately.
    Timing chain components, valve cover, carbon (walnut blast) cleaning of intake valves, FRM computer and now a plastic housing that seems like it's cracked and has many sensors going to it. It's located underneath the HPFP/vacuum pump, I could only visually see it after removing the air intake pipe that leads from the airbox to the turbo. Is this a common problem? Why oh why does Mini make it out of plastic? :eek6:
    Help appreciated!
    Regards Systemlord.
  2. r34king
    r34king Member
    Aug 18, 2011
    71
    34
    Auto Tech NTB Capital BLVD
    Thermostat housing/ assembly
  3. Dave.0
    Yup and why does MINI use so much plastic...it's cheap and light but mostly cheap.
    Yes lots of plastic in our MINIs & every other car & truck on the road. Some advantages, you can cast an intake tract in ways that would be difficult or impossible to do in aluminium, yep it is cheap & light too. Disadvantages a plenty though. When that stuff gets old it is brittle. I wonder how these modern cars will be kept going when they are 25 or so years old.
    Back on topic leaking plastic parts....
  5. Systemlord
    Mar 28, 2013
    311
    67
    Thank everyone for replying, is the main pump located under the thermostat housing? If it is is it a good idea to replace the main pump as well? I'm just under 50,000 miles. I appreciate the plastic intake manifold for its smooth inner surface and weight saving but these plastic parts for the coolant system is a failure on Mini's part! There are some things that shouldn't be plastic in an engine and the thermostat housing is one of those!
    I agree with you. The thermostat housing is plastic on my 06, on my third one. It appears MINI did not improve the design on the newer cars.
  7. Dave.0
    I am also on my 3rd one, wait maybe its my 4th one, :idea: I don't know.
    We'll be printing them.
    [ame=http://www.youtube.com/watch?v=CD7yB9gZDIk&sns=em]The Future of OEM parts: 3D Printing replacement Car Parts? - YouTube[/ame]
    Will that work for old burnt out smoking ECUs too?
  10. Systemlord
    Mar 28, 2013
    311
    67
    These thermostat housings are a ticking time bomb, even after you replace it!
    Stupid Mini, what the hell were they thinking? Better yet they don't even bothering with an improved design...
    This is the definition of negligence in car manufacturing, they should be slapped in the face by a cold dead wet fish!
  11. pcdude
    pcdude New Member
    Jun 16, 2014
    I just discovered my 08 is now leaking under pressure. It was a challenge to find the leak because there's so much in the way of the housing. Mine seems to have a crack towards the rear of the housing along the seam. Anyone know how many liters of fluid are needed to change out the housing? It's mounted high in the system so I'm guessing we don't need to drain the system down too much. I'm guessing 1-2 liters and about the same in distilled water should do it.
  12. MCS02
    I can't help sorry but ill give you a bump
  13. oldbrokenwind
    oldbrokenwind Active Member
    Oct 18, 2012
    196
    107
    Northern NV
    Changed mine about a month ago. Dealer's SA suggested using some silicon sealant around the outer edge of the gasket --- helps retain a seal when the plastic starts to deform.
    Didn't measure the fluid qty --- fluid was fresh before leak was found, so it was saved, filtered and re-used. Very little was wasted.
  14. pcdude
    pcdude New Member
    Jun 16, 2014
    I also filtered and reused the fluid. The water pump was replaced recently and the fluid was also replaced. Needed to top it off with about a liter due to coolant that was lost when the hoses were pulled off the thermostat housing.
    Great YouTube video of the replacement procedure worth watching if you need some tips.
    [ame="https://www.youtube.com/watch?v=ek4YJUvZTPc"]Replace R55/R56 MINI Thermostat Housing Cooper S / Clubman S P0597 OBD code - YouTube[/ame]
