2nd Gen R56 Cooper S Coolant leak?
Discussion in '2nd Generation: 2007+ R55 through R61' started by Apok, Sep 19, 2015.
  1. Apok
    Apok New Member
    Jun 15, 2013
    776
    357
    So out of nowhere this morning on a short errand trip with no agressive driving, I get the yellow temperature warning indicator. It went away about a min later. I thought this was odd as it was only about 75 out this morning. Much to my horror about a min later the red temp warning came on. I pulled over and shut the car down for a moment to let everything cool off so I could finish my relatively short drive home, less than 5 miles. In that time the red indicator went off and on several times went off and on several times and then a yellow check engine light came on. It's only Saturday morning, I mean come on!!!!
    Once home I throw the hood open as I can smell coolant and get a bunch of steam coming from the right side of the engine, below the intake tube but above the transmission and the cooling fan was running at full force. And I decided to just let it cool off before I got to looking around.
    Due to the placement of the intake tube I can't see what is going on or where the leak is coming from, however I can see that there is coolant pooled on top of the transmission.
    Any thoughts? I made an appointment to get it into mag on Monday morning. Woulda been a nice day to go for a drive.
  2. BlimeyCabrio
    Usually a failed thermostat gasket or housing, when there's coolant in that location.
    FWIW, the convention is to refer to that as the "left" side of the engine.
    I'm glad you made it home. When you get those warnings it's best to stop open the hood & investigate. I'd guess the Jarvik 7 has died.
  4. Firebro17
    Water Pump??
  5. Apok
    Apok New Member
    Jun 15, 2013
    776
    357
    I was thinking either that or the water pump. Ugh, this is gonna cost me.
  6. Metalman
    ^^^ Hope the head didn't warp...
  7. Motoring Magic
    Motoring Magic New Member
    397
    266
    Thousand Oaks, Vta cty, socal
    Thermostat assy
    the thermostat assembly will have a crack in one of the rounded corners, we replaced 2 yesterday. Part of ownership of an R56 series car. If your car has more than 60k on it, ask them to replace the coolant transfer tube that runs from the T stat to the back of the water pump housing-it is going as well and you will just have to pay t stat labor again to get it replaced soon......We never replace a thermostat without the transfer tube anymore. These are a 60k maintenance items on those cars anyore....
  8. Firebro17
    I just know that what you described, is exactly what happened when my electric water pump went out on my 5 series BMW last year. MM gave some great insight to be considered and focused upon for sure.
  9. Apok
    Apok New Member
    Jun 15, 2013
    776
    357
    Thanks for the heads up.
  10. Apok
    Apok New Member
    Jun 15, 2013
    776
    357
    That's what it was. Tstat was borked.
  11. Motoring Magic
    397
    266
    and you paid the extra 180ish (dealer prices) to have the transfer tube done, right?:wink:
  12. Metalman
    ^^^I was wondering the same thing...
  13. 00Mini
    2,263
    Nice to hear your problem was solved !!
  14. caseydog
    caseydog Well-Known Member
    Nov 7, 2012
    2,433
    879
    Automotive Photographer
    Dallas
    In the three years I have owned mine, I think I have had to replace every gasket and reservoir on the cooling system, and a couple oil gaskets. Lucky for me, I have an extended warranty, so the cost has been manageable.
    I believe the first gasket to go was the water pump gasket. That one leaked at a pretty fast rate. I had to stop and add water on the 15 mile drive from my house to the MINI dealership.
    CD
  15. Apok
    Apok New Member
    Jun 15, 2013
    776
    357
    Yeah, sure did. Cost me a bloody fortune! But the baby is all happy and purring along like normal.
    Though honestly for the cash I had to fork out, it really should got a little faster!!
  16. Metalman
    The thing is.... It could have gotten a lot slower....
  17. Apok
    Apok New Member
    Jun 15, 2013
    776
    357
    I'm just glad I didn't overheat it too much and warp the head. I really couldn't have afforded a new head.
  18. Metalman
    For sure.... parts and labor would be something I bet...
  19. Zapski
    How many miles on it?
