1st Gen JCW Coolant temp question
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Mini06JCW, Feb 14, 2012.
  1. Mini06JCW
    Mini06JCW New Member
    Feb 14, 2012
    I just bought a Mini 2006 JCW. The coolant temp is running around 160-190. Any ideas what may be going on? According to the manual that isn't normal.
    How are you determining the coolant temp?
    Welcome to Motoring Alliance, thanks for joining.
  3. Mini06JCW
    Feb 14, 2012
    The Coolant Temperature Gauge. It's reading around 170- 190 most of time.
  4. Jason Montague
    :cornut: No help here as Margi is 2nd Gen 08 R56 MCS/JCWm but, her standard operating temp is 220F(ScanGauge II). When I first got her, that temp range bothered me as I thought that it was way too high but, after considerable research, no that's nl temp.:Thumbsup:
    I'd think the thermostat is stuck open. Ten again, that was the case with the last person that asked a very similar question.
    Does the cabin heat take longer to come up to normal than usual?
  6. Minidave
    4,594
    What does the manual say? I think that's the normal range for 1st gen engines, 2nd gen engines run much hotter, around 220F
    I haven't seen any temp gauges with numbers on them, do you have the chrono pack or something? or an aftermarket gauge?
    I think that it is a little cool for a 1st gen. Granted, I don't have a gauge to tell me normal but I'm thinking that since there was at one time a 180F thermostat available in the aftermarket that the OEM one opens at a higher temp leading me to think that the range the OP has posted is a bit cool.
    I could be wrong, it happened before.
  8. Minidave
    4,594
    If it's a 180* thermostat, it will run between 170-190, as it opens/closes, fan cycles etc. Seems right to me.....I know the 1st gen engines ran cooler than the 2nd......what does the manual say, as the OP said the manual said that range was "wrong"....
  9. ScottinBend
    Stock 1st gen thermostat is around 200°.
    Before replacing anything verify that the gauge is correct first.
