Brakes Wheels 1st Gen Tires Corrected Speedo inaccuracys
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by docv, Nov 14, 2010.
  1. docv
    docv Well-Known Member
    818
    280
    moble auto paint tech ( PTU )
    Central Missouri
    I put a different set of wheels and tires on my MINI and the speedo is now dead on. Like everyone else the speedo was 4 or 5 MPH off, I removed a set of 15" 175/65 R15's and replaced with a set of 16" s-lites with 205/55 R16's and that corrected the error. 70 MPH is confirmed with the Garmin the same up and down the dial.
  2. lotsie
    stagehand/part time detailer
    Right here
    Great!!! Now you can confirm your speeding.
    Mark
  3. Metalman
    I cross referenced it. So it looks like a tire diameter of 24.9" is the sweet spot for accurate speedo readings. Tires not trunks.:D
  4. lotsie
    Right here
    I was 14 the last time I fit a 24:lol:
    Mark
  5. Justa Jim
    Tried that and Docv is right in it correcting the speedo. It also killed acceleration and mpg, on my justa, due to extra weight, so I went back. Have you noticed a change in these two things since you put the larger tires on?
  6. docv
    818
    280
    Central Missouri
    Havent noticed much yet, just put them on Friday. I can tell it sticks the corners better, the tires I put on are Goodrich G-Force. Wont get to check out MPG for a week or so.
  7. Justa Jim
    I just realized that you and Lotise have R50's and I have an R56. The gearing might be different enough to make them react completely opposite.
  8. lotsie
    Right here
    I'm quicker on a smaller overall tire size. Smaller as in less tall.
    Mark
  9. docv
    818
    280
    Central Missouri
    The gearing is strange on the R50, it the only car I have ever owned that you can drive 35 or 40 in any gear, and it has always felt like it needs that sixth gear.
  10. Justa Jim
    Interesting. I have that sixth gear and I lost a lot on a larger tire.
  11. goaljnky
    3,105
    394
    I am still 24. But I have to measure my thigh to get that.
  12. BThayer23
    The wider tire will affect your MPG, too, beyond just the gearing differences - more rolling resistance.
  13. Justa Jim
    Yepper, I found that out. :frown5:
  14. Angib
    I went back to 15s from 16s last week (for my first ever drive on winter tyres, which just aren't used in Britain). The first thing I noticed was just how much livelier the car is, particularly on acceleration from a standstill.
    I have trouble believing that I could feel the difference in a 2% change of gearing - but then I don't think the 30% reduction in wheel weight is all that significant either. so I can't explain what I feel.
  15. Justa Jim
    I can't tell what type MINI you have, but mine is a R56 and the weight made a real difference. I plan to go to lighter wheels too, as I think that will also be a help. Second generation justa's are not like the MCS, but can be made more responsive in in different ways. I am back to the stock size, but the Yokohama tires I got handle very nicely in the turns.
  16. Rooster
    Rooster New Member
    May 22, 2009
    Systems Engineer
    West Hollywood, CA
  17. Justa Jim
    Get a Scan Gauge. The MPH readout is adjustable.
  18. BThayer23
    I had a shop calibrate my speedo a few years ago. I'm not sure what's involved mechanically, but it got me out of a speeding ticket. :D
