1st Gen R53 Cooper S Cracked catalytic converter
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by BThayer23, Mar 29, 2011.
  1. BThayer23
    Midway through my track weekend a few weeks ago, I noticed that I had an exhaust leak. It wasn't throwing codes, it just sounded bad, so I kept driving. A week later, when I had time to get it warm and up on ramps, I could feel air pulsing out from the downstream edge of the second catalytic converter, right on the bottom. It felt like just a small hole, so I figured I'd take it in and get it welded up.
    So the mechanic calls me up and says, nope, it's not a small hole, it's a crack 3/4 of the way around the cat. :eek6::eek6: It's gonna be 2-3 hours of labor to remove and reinstall the header, then an hour of labor to weld it all the way around, plus gaskets. I might try to R&R it myself. Or I can just replace the whole thing with an OEM or aftermarket header.
    Any ideas? Money is an issue, more power would be nice, but reliability is probably the highest priority. It's gotta hold up to track days and road trips, which are mostly to and from the track, and I don't want to wear ear plugs. Yes, I'm aware that there are several sponsoring shops making headers, and I'm not really looking for opinions on whose is better or worse, I'm just wondering what my options are for a street-driven car.
  2. BThayer23
    And as for mods, I have a stock engine with a Milltek catback.
  3. Mr. Jim
    So what do you have on there now? Aftermarket header or OEM manifold? Might be easier to go with the OEM setup.
  4. minimark
    Given the fact that you have 92,000 miles on it and the cat is most likely if not already bad, then the fact that an OEM is so expensive.... RMW street header.
  5. Metalman
  6. BThayer23
    I have the OEM manifold, cats, O2 sensors, everything.
    Hmm, that looks like the cheapest option, and not a bad one.
    Yeah, the shop was quoting me $1300 for a new OEM exhaust manifold, and pelican lists them for $1450... :incazzato: So an RMW header would be cheaper.
  7. minimark
    And better! ;)
  8. ScottinBend
    As has been said by the guys at Mynes.......aftermarket cat's don't last long on the high temp MINI's. Get an OEM cat and have it welded on. Check with Mynes for a price.
  9. mini_racer
    mini_racer Well-Known Member
    Engr Manager
    #9 mini_racer, Mar 29, 2011
    1st gen MINIs seem to be rough on exhaust systems.
    If you are wanting to have the quietest option for the least $$, then get the cat that Metalman found. That looks like a decent option.
  10. Mike
    Mike New Member
    This!
  11. Motoring Magic
    Motoring Magic New Member
    397
    266
    Thousand Oaks, Vta cty, socal
    we fix em
    here we charge 2.5 hours (95/hr) plus the gaskets for the r&i, and the fabricator accross the street usually charges 100ish to make them look like they were never cracked-and the ones I have done were completely seperated att he crack!
  12. BThayer23
    Any idea how long they last after the weld? And will it stand up to track abuse?
  13. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    We charge 1.5 hours to remove, weld, and re-install the cat. That's a common failure.
    10,059
    ^ That is a deal..... :Thumbsup:
  15. BThayer23
    You ain't kidding. Some mornings it takes me 1.5 hours to get dressed, eat breakfast, and tie my shoes. And I eat instant oatmeal! :D
  16. minimark
    Dang, must spend a long time in the reading room...lol
  17. BThayer23
    Those mornings are usually preceded by a head swap worth of time at the bars...
  18. minimark
    So what did you decide to do about the cat? :)
  19. BThayer23
    I'll post pictures when it's installed.
  20. BlimeyCabrio
    I wonder who is gong to install it? :cornut:
