Cracked Hose - What is it?
Discussion in '2nd Generation: 2007+ R55 through R61' started by Holly Guillot, Aug 24, 2018.
  1. Holly Guillot
    Holly Guillot New Member
    Aug 24, 2018
    Female
    My Mini Cooper 2011 Clubman had a temperature light come on. When I looked under the hood, a whitish substance was sprayed on the back area - in picture. I see a piece of hose that is separated. I have tried to identify where it is (underneath the arrow) and circled the separated hose/pipe. What is this?
    I am not very mechanical so I apologize in advance.
    Thank you - Holly
  2. wmwny
    4,048
    2,246
    Welcome to M/A!
    I cannot be of help, as my MINIs are all Generation Ones, BUT...there are plenty of the newer generation owners here who will give you the advice/solution you need.
  3. MCS02
    I cant really tell. I looked on my wife's Mini but that was no help. Does it have any antifreeze left in it?
    • Informative Informative x 1
  4. MCS02
    Welcome to MA!
  5. Holly Guillot
    Aug 24, 2018
    Female
  6. Holly Guillot
    Aug 24, 2018
    Female
    Thank you for looking. Hopefully someone with that generation will know. Everything is so compact it is hard to get a good picture.
  7. MCS02
    Yes it is packed in there. I will look at the Bentley manual later today and see what I can find. We have two Gen2 Minis and one Gen 1. Is yours an bace, S, or JCW?
  8. Holly Guillot
    Aug 24, 2018
    Female
    Hi. It did loose antifreeze. Unfortunately that is a problem with this year Clubman. So I was not sure of this is r
  9. Holly Guillot
    Aug 24, 2018
    Female
    The mini is a "S" model.
  10. Holly Guillot
    Aug 24, 2018
    Female
    This is the piece it is connected to if that helps.
  11. Holly Guillot
    Aug 24, 2018
    Female
    Under the back part. I would like to know so that when I go to the repair shop, I am familiar with the problem.
  12. wmwny
    4,048
    2,246
    Come on, all you later Generation MINI people! Lend a lady your "expertise"...she's in need of knowledgeable advice [which leaves ME out], but some of you know-it-alls should make short work of her problem!
  13. clifforddward
    clifforddward Active Member
    Dec 2, 2013
    104
    76
    Cary, North Carolina
    Hi Holly:
    I'm a R53 guy so don't have an exact car to compare for diagnosing your problem...but as nobody else has commented I'll give my thoughts.
    The hoses you pointed to/circled appear more like vacuum hoses to me, unlikely to be the source of your fluid spray...but if disconnected they do need to be addressed.
    The first thing I'd do is refill the antifreeze and add some leak detector...that way you can use an ultraviolet light to locate the source....And I'd also put a pressure tester on the system...that in combination with the leak detector will make short work of finding the source of the trouble. If you're not much of a gear head you may not have these tools, but at least now you'll know what the shop is going to use to find your problem....so you can speak intelligently with them as they diagnose things.
    I would think they should be about to diagnose it without taking the car apart....if they say they need to pull it down just to source things, that would be a red flag.
    Wishing you the best...let us know how you make out...
    Best Regards,
    Cliff
  14. MCS02
