Crank but no Start issue, please help, thanks
Discussion in 'Starting Line - New Member Introductions' started by Toroven, Aug 20, 2017.
  1. Toroven
    Toroven New Member
    Aug 16, 2017
    hello everyone! my name is john and i live in Australia, Im glad to have found this place, I have a 2006 R50 Mini and i am hoping to find an answer to a starting problem that i currently have.
    the car cranks but does not start, I've replaced the CPS sensor, Camshaft Sensor, Coil Pack, Spark plugs, New Battery. There is plenty of fuel on the fuel rail, but there is no spark coming from the coil, i Would greatly appreciate your help in solving this mystery, thanks.
    Welcome to MA! Is it showing any codes? Are you using a stock coil pack, the after market ones have given some people problems. Also are you gettin power to the coil pack? Did you pull a plug to make sure you are not getting a spark? When you say you have plenty of fuel at the rail did you put a pressure gage on it to make sure it's the proper psi?
    Sorry for so many questions.
  3. Zapski
    Welcome!
    It kinda sounds like a traditional starter issue, but then I'm still a n00b for this kind of stuff. Someone with real knowledge will show up soon.
  4. HillbillyChili
    Jun 14, 2017
    91
    29
    Software
    Hey mate!
    Check fuses, after that see if you can hear your fuel pump run, after that might be worth taking to the shop.
    Welcome to the club!
