Interior 1st Gen Craven ScanGauge Mount
Discussion in 'Tuning and Performance' started by Batrugger, Dec 31, 2009.
  1. Batrugger
    Batrugger New Member
    May 13, 2009
    463
    92
    Soldier
    Hesperia, Ca.
    I have been wrapped up working on the VW's lately, but we still have a MINI and it needs love too. I got the little bits from Craven to finally mount the Innovate XD-16 gauge for the wideband AFR and finally a great way to mount the Scangauge:
  2. Mike
    Mike New Member
    Neat! Right where you can see it without taking your eyes off of the road. I high-mounted my wideband in the same place.
  3. jiminni
    jiminni Well-Known Member
    262
    Ca.
    Me likey, need to get one of those mounts.
  4. ScottinBend
    You guys can actually see those there?
    I wouldn't be able to see anything above the tach. As it is now I can't even read the top of the tach dial. And I am 6' tall.......
  5. Justa Jim
  6. versus
    versus Active Member
    Sep 8, 2009
    553
    87
    Pardon the purely nooooob question, but what's the purpose of said gauge?
  7. RonsMinnie
    RonsMinnie New Member
    449
    Sugar Land, TX
  8. Dwight
    Dwight Racing with the Gods
    329
    12
    RETIRED!!
    San Marcos, Calif.
    Can't do the top tach mount on an R56 as the wheel blocks the view. Didn't think I could do a side tach mount do to gauges, but your pics gave me an idea :idea:. It works!! Used 3M 2 sided tape and will fine tune the viewing angle tomorrow. Poor pic as I got kinda excited when I found it would fit (barely). Thanks :Thumbsup:
  9. jiminni
    262
    Ca.
    Just checked today, your right cant see it up there.
  10. Batrugger
    May 13, 2009
    463
    92
    Soldier
    Hesperia, Ca.
    That's funny, my wife is 5 ft tall and has no problem seeing it. I sat in there it is plainly visible to me when I get everything adjusted for my 6'1 height. The only gauges that are partially blocked are the two bigger ones on the sides.The mount for the Scangauge can be moved around though to be positioned almost anywhere around the tach.
  11. ScottinBend
    Are you seeing it above the wheel or below?
  12. Batrugger
    May 13, 2009
    463
    92
    Soldier
    Hesperia, Ca.
  13. jiminni
    262
    Ca.
    I got one today, the mount. I am going to mount it on the right side of tach and have a dual mount on the left.
  14. Dwight
    329
    12
    RETIRED!!
    San Marcos, Calif.
    Here's the final mount. A clear view thru the wheel and cable out of the way. Used Velcro to secure and give wriggle room to get correct sight angle. Hope this helps if you've got an R56 that already has gauges. :D
  15. checkers
    checkers Well-Known Member
    Jun 11, 2009
    4,009
    962
    Modesto, Ca
    I don't have any trouble seeing mine.
  16. jiminni
    262
    Ca.
    #16 jiminni, Jan 3, 2010
    Just changed up my setup. Went to a dual gauge setup on the left side, used two single pod's and a "y" connector, I like it better than the dual pod setup. On the right side I installed my Scangauge with Cravens new Scangauge bracket. I think it came out nice?
    DSC02171.jpg These are the new Marshall Mini specific gauges BTW.
  17. Kellen@Craven
    Kellen@Craven New Member
    36
    Talking about Minis and stuff
    Portland, OR
    That looks nice. How do you like the look of the splitter? I think We are going to be using those instead of the dual-cup going forward.
  18. jiminni
    262
    Ca.
    #18 jiminni, Jan 4, 2010
    Thanks! I like it better than the one piece dual pod, but Steve has a great idea for the one piece unit, when you have a peak recall button, for stepper gauges, you can drill a hole in between the two gauges and install it there, would look very cool. I had a brainstorm and am going to be mounting a remote Valentine radar detector modual on a Scangauge bracket right above the Scangauge. The Valentine is a little wider though.....so.....? I think it will end up very cool.
  19. Batrugger
    May 13, 2009
    463
    92
    Soldier
    Hesperia, Ca.
    The splitter was the only way that I could mount the two different size gauges. I had that Innovate wideband LC-1 installed for 6 months with no gauge until I saw that splitter on your site and it worked great.
  20. Kellen@Craven
    36
    Portland, OR
    Sounds good. I'd like to see that. People have asked about a FlexPod Radar Detector module, there are a lot of radar detector options out there though.
