1st Gen R53 Cooper S Cruise Control Problem R53
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Yeah BB, Sep 12, 2010.
  1. Yeah BB
    Yeah BB New Member
    Jul 11, 2010
    Hey There,
    I have been having a cruise control intermittent problem for awhile now and have not been able to figure it out. It works when it want's to. Some times for several days and then others it will not work at all. When it does not work the light will flash once and then go off. I am not able to find any common factors that are in play when it does or doesn't work. Has anyone ever had this problem?
    Thanks for any input.
  2. Minidave
    4,593
    A couple of fairly easy things to check.....brake and clutch switches - they claim these fail on a regular basis and are inexpensive and easy to change - check the adjustment first.
    My car also went thru this problem and after 2 brake switches didn't cure it the dealer changed the steering angle sensor next, then the ignition switch (electrical part only, not the keyed part), which seemed to finally fix it.
    Good luck!
  3. Yeah BB
    Yeah BB New Member
    Jul 11, 2010
    #3 Yeah BB, Sep 19, 2010
    Thanks Minidave! I will get it a shot and let you know if I was able to fix it. I do have one question though. If the brake switch was bad wouldn't the brake lights not work? Oh and if I failed to mention it's an automatic so I don't have a clutch switch.
  4. Minidave
    4,593
    So, are your brake lights working?
    I don't know the answer for sure, there may be more than one switch - one for the cruise and one for the brake lights - but again, fairly easy and inexpensive to check.
  5. Yeah BB
    Yeah BB New Member
    Jul 11, 2010
    Yep they work fine. I will get a chance to look at it today after work. I should get home before dark today. From what I see in the manual there is only 1 switch.
  6. 2003Mini S
    2003Mini S Member
    Sep 26, 2016
    36
    I seem to have same issue....flashing once and not engaging.
    Did you find out what it was the problem?
