CUSTOM TURBO TWINCHARGE KIT
Discussion in 'Classifieds Archive' started by 160SWIFTLY, Sep 4, 2012.
  1. 160SWIFTLY
    160SWIFTLY New Member
    Jul 24, 2012
    27
    #1 160SWIFTLY, Sep 4, 2012
    $3,000 plus 3% paypal
    Selling my Custom built twincharge kit for Supercarged MINI's. Never installed changed my mind and going to stick with just a supercharger. Header is made of cast stainless It feaures a 3/8 inch thick stainless flange and a T3 turbo mounting flange. It is set up for a 38mm or 39mm wastegate.
    The Down Pipe has a two bolt style 3/8" thick flage that will mount up perfect to any OEM or after market Cat Back Exaust (Though I highly recomend after market). It also has a 3" flex pipe and O2 sensor bungs that is of an OEM exhaust manifold. It DOES NOT have a cat. converter. Also has a 5 bolt exhast flange-to-turbo.
    To mount this unit in you cooper s is nothing to challenging. You will have to relocate your power steering fluid tank and the coolant tank. Lots of trial and error went into getting the pipe to fit just right. It does not hit anything and has pleanty of room for the top half to hinge on the flex pipe.
    Included in kit is everything you need to bolt it in your mini. Mounting turbo to header is a bit difficult tho.
    Kit includes..
    custom built Down pipe.
    custom built Header. Wrapped in DEI titanium heat wrap.
    Turbonetics 50 Trim Turbo 350HP. Bought used with 3,000 miles.
    Precision Turbo PW39 External Wastegate. Brand new.
    Turbosmart vee-port Blow Off Valve. Brand new.
    -10 AN and -4 AN oil lines and fittings.
    Silicone couplers and T bolt clamps.
    10FT 4mm turbosmart vacuum hose.
    Gaskets.
    IMAG0384.jpg IMAG0385.jpg IMAG0386.jpg IMAG0387.jpg IMAG0388.jpg IMAG0389.jpg IMAG0390.jpg IMAG0391.jpg IMAG0392.jpg
  2. drabdub
    drabdub Well-Known Member
    Oct 22, 2009
    1,035
    Logistics Lead
    San Jose, CA
    if i had an S i would be all over this. guess i need to start looking for one
  3. Minidave
    What sort of ECU tuning would have to be done to get this to play nice with the supercharger?
    What about larger injectors and perhaps an overboost injector? Does this boost thru the intercooler too, or not?
  4. 160SWIFTLY
    Jul 24, 2012
    27
    #4 160SWIFTLY, Sep 5, 2012
    The only tuning I was going to do was with an apexi neo which is a fuel tuning device. I can throw it in for $250 more.
    And yes it boost through the intercooler.
  5. ChrisMCS04
    ChrisMCS04 New Member
    May 12, 2009
    92
    14
    Darn nice looking kit you have here.
  6. 160SWIFTLY
    Jul 24, 2012
    27
    #6 160SWIFTLY, Oct 1, 2012
    Bump
  7. 160SWIFTLY
    Jul 24, 2012
    27
  8. jiminni
    jiminni Well-Known Member
    262
    Ca.
    Couldn't someone just use it as a turbo only kit? Maybe the "twincharge" is scaring people away?
  9. 160SWIFTLY
    Jul 24, 2012
    27
    #9 160SWIFTLY, Oct 30, 2012
    Yeah I think its possible just need a intake manifold off a R50 and a FMIC
  10. Helix Wildebeest
    Helix Wildebeest New Member
    Feb 29, 2012
    33
    54
    I can tune this no problem.
  11. 160SWIFTLY
    Jul 24, 2012
    27
    Anyone wanna make an offer?
  12. 160SWIFTLY
    Jul 24, 2012
    27
    I can't believe no one wants this??
  13. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    Mr. Wildebeest can tune it, I can provide a larger-than-stock supercharger pulley--you're so close to 300 WHP...
  14. drabdub
    Oct 22, 2009
    1,035
    Logistics Lead
    San Jose, CA
    Wishing I had the money
  15. 160SWIFTLY
    Jul 24, 2012
    27
    Make an offer
  16. 160SWIFTLY
    Jul 24, 2012
    27
    #16 160SWIFTLY, Dec 30, 2012
    bump
  17. 160SWIFTLY
    Jul 24, 2012
    27
    #17 160SWIFTLY, Dec 31, 2012
    Bump price drop $1,800 OBO need to get rid of this for other things.
    Had a guy make a deposit and it was sold for $2,800 but he backed out:mad5:
  18. 160SWIFTLY
    Jul 24, 2012
    27
    Price drop $1,500
  19. drabdub
    Oct 22, 2009
    1,035
    Logistics Lead
    San Jose, CA
    What would It cost to tune this just trying to look at total cost for all associated parts before I try to pick it up
  20. 160SWIFTLY
    Jul 24, 2012
    27
    I would get a hold of the guys from helix and ask them.
