CVT transmission going forward in Reverse.
Discussion in 'Starting Line - New Member Introductions' started by BLAYNE, Nov 2, 2016.
  1. BLAYNE
    BLAYNE New Member
    Nov 2, 2016
    6
    Hi Guys, New to the forum and mini coopers. Ive rebuilt the transmission in my 2003 mini cooper, replacing the belt. Now when I put the car in reverse it goes forward. park dosnt move. Any ideas. Ive had this in and out 5 times. Begging. lol
    6,328
    Welcome to MA! I wish I could help, but I have to ask, does it go backwards in drive? Their should be someone along that can help more than me.
  3. BLAYNE
    BLAYNE New Member
    Nov 2, 2016
    6
    Thanks for the Welcome. This tranny is driving me nuts. Goes forward in Drive
  4. BLAYNE
    BLAYNE New Member
    Nov 2, 2016
    6
    My Ideas are, Valve Body-Solenoid-or Reverse Idler?
  5. MCS02
    6,328
    If you are sure you did the rebuild correct have you checked the leakage to make sure it is correct? I have never had a CVT apart those are very problem pron transmissions. Do you have a Bentley manual?
  6. BLAYNE
    BLAYNE New Member
    Nov 2, 2016
    6
    There is not a lot of documentation on these transmissions, so it is grasp one idea from here one idea from there. topped up no leaks. no extra bolts. Ive had the transmission apart 5 times.
  7. MCS02
    6,328
    I don't think there is anything in the Bentley manual. I am not home I will check tomorrow when I get home and see if it addresses anything to do with the CVT.
  8. 05r50
    05r50 Well-Known Member
    Dec 4, 2010
    1,269
    696
    Not that this helps you at the moment, but I thought that there was some shift lever process you had to do after the transmission job to "reset" everything.
    Like park to N to P to D to P (or some such crazy scenario)
  9. BLAYNE
    BLAYNE New Member
    Nov 2, 2016
    6
    n
    found the service manual for the 2003 mini, gives the oild change procedure but nothing on the internal workings of the tranny. still no clues.
  10. MCS02
    6,328
    here is all I could find.
  11. MCS02
    6,328
    and this
  12. 05r50
    Dec 4, 2010
    1,269
    696
    Bingo. That was what I was remembering.
    Hope this helps the OP.
  13. Qik
    Qik Well-Known Member
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    Convert to manual, and Welcome to MA!
  14. BLAYNE
    BLAYNE New Member
    Nov 2, 2016
    6
    anyone know how to reset the cvt software without purchasing the bmw software
