Engine Drivetrain 1st Gen Cooper S De-cat or Megan header?
Discussion in 'Tuning and Performance' started by Tummi_Gummi, Apr 14, 2016.
  1. Tummi_Gummi
    Tummi_Gummi New Member
    Nov 19, 2012
    384
    103
    Online Sales Manager
    Springfield, MO
    I have the OEM header with a gutted cat but I could reach the pre cat which I've heard is the most restrictive since it catches everything and builds up. My question is should I pull it and try to find some type of wire that I can bend and shank the precat out with or just buy the Megan header for 240? I have a fully modded mini minus a bv head.
    Sent from my XT1254 using Tapatalk
  2. caseydog
    caseydog Well-Known Member
    Nov 7, 2012
    2,433
    879
    Automotive Photographer
    Dallas
    I would, personally, go with a muffler bearing upgrade, instead. OEM muffler bearings are a huge drag on horsepower.
    CD
  3. Tummi_Gummi
    Nov 19, 2012
    384
    103
    Springfield, MO
    I have an invidia n1 cat back with resonator delete. I have every bolt on and a race cam.
  4. Grizld700
    Grizld700 Well-Known Member
    Feb 2, 2016
    1,212
    47
    Eastern Iowa
    Well, not eeeeevery bolt on. You need a header remember :wink: :D :devil:
  5. 00Mini
    2,227
    If'n you have a much modified engine doesn't it stand to reason you would want to free up the exhaust with a less restrictive header ??
  6. Tummi_Gummi
    Nov 19, 2012
    384
    103
    Springfield, MO
    I heard the OEM header was already bigger than the ports on the head? Is this not true? I have Ddm works CAI, racing engine mounts, SSK, Air diverter, race cam, tune, 15% pulley, catback
  7. MCS02
    Everyone I have talked to has said the RMW header is the best on the market.
  8. caseydog
    Nov 7, 2012
    2,433
    879
    Dallas
    Okay, so this is a race car. I wasn't sure. Laws are different for street cars. So, get you a coat hanger and a drill and gut those pre-cats.
    CD
  9. MCS02
    R53s don't have a pre cat. You can get a high flow cat so you don't lose any performance.
  10. mrntd
    If I'm not mistaken if you gut the cat the cpu will not be happy because it is expecting to see different readings between the pre-cat sensor and the post-cat sensor. You would definitely need a tune that compensates for that. I've done gutted cats or cat by-pass in the past but they were on older cars that only had 1 sensor pre-cat.
  11. Dave.0
    Since you are into making poor decisions buy the Megan header. :Thumbsup: :popcorn::lol:
  12. Tummi_Gummi
    Nov 19, 2012
    384
    103
    Springfield, MO
    Captain troll
    Well, What OS the cat looking thing between the runners and the flex joint? Looks like the cat but mini. Is this not a pre cat? And all that removing the cat will do is give p0420 code and give Leonardo DiCaprio a heart attack.
  13. MCS02
    When I put headers and exhaust on my Mini I did not de-cat. I just don't see the use. In the old days before high flow cats I would. But now You are not losing by keeping a cat if you go with a high flow one. You can get a RMW shorty header with a high flow cat for around $1000. This is the best solution out there. I wish I had known about it when I did my exhaust. Now I get to do it agin.
  14. Dave.0
    Troll :lol::lol::lol:
    It's not a pre cat it's called a collector for the four exhaust pipes before the connect to the flex section. It's also known as a sh!tty MINI design. Save your pennies and buy an RMW street header. While you are saving for a quality header try reading more and posting less. :ihih:
    You would learn a lot.
  15. Tummi_Gummi
    Nov 19, 2012
    384
    103
    Springfield, MO
    Same to you. People wouldn't bash you quite as much. They might forget about you but then this forum would be boring without its drama queen.
  16. Dave.0
    Really that's the best comeback you have. :lol::lol::lol::lol:
    Not to mention I was right about your OEM exhaust manifold.
  17. ZippyNH
    Chill....I think Dave-o has some VERY valid points...
    Let's face it...your mini experience has been...er...uneven, with a steep learning curve. Folks are just trying to help guide you...
    If you don't want to learn from our experiences, don't ask, and certainly don't ridicule us please.....
    Cheap headers work...for a bit..the OBX units are famous for cracking...the lack of a flex joint...
    IMO since you have " every bolton possible " the stock header is holding you back...get the best, the RMW, weld on a high flow cat, and be done....if you want to go pennywise and pound foolish....well...we will keep reading your threads.... Maybe even reply. Honestly, they are somewhat entertaining....everybody knows somebody who seems to have terrible luck...the equivalent of a slow motion train wreck...and here we get to read what goes into it...
    My take...
    Buy your parts, have a good car....
    Buy junk parts cheap...have a junk car.
    Nuff said. You have spent so much to this point, on a STOCK HEADER....wow...if you want too keep the car, get a good one...
    If you expect the dump it in a few months, toss an OBX or eBay special on it...either way, it's not gonna pass inspection, so it better be an off road race car only.
    If you want a street legal car...the RMW header, with a cat is a good choice.
  18. Nathan
    #18 Nathan, Apr 22, 2016
    Being it's Earth Day and all....
    Use a catalytic converter dang it, your grandchildren will thank you.
    As to header choices.
    OBX or Ebay - JUNK
    Megan - Slightly better Junk
    Manzo - Even worse than OBX level in junkiness, a waste of metal.
    Milltek - Nice stuff
    RMW - Really nice stuff, come in short or race.
    There may be others out there. I have seen and / or used all of the above.
    We've had this discussion, it's fine that you bring it back, always nice to cover old material to see if anything has changed. http://www.motoringalliance.com/forums/cooper-s-engine-and-drivetrain/13975-r53-headers.html
  19. Tummi_Gummi
    Nov 19, 2012
    384
    103
    Springfield, MO
    Just tired of Dave's attitude. Thanks everyone. I don't post very often anyways. I come and go, never really been to impressed the hospitality here. There are a few nice people on here that have been very informative and then some that have just been moody. I'll probably just go for a Megan header for now. Maybe when I get the sprintex and BVH I'll grab a rmw when I get the rmw head so I can have it blueprinted and a gasket to match.
  20. Tummi_Gummi
    Nov 19, 2012
    384
    103
    Springfield, MO
    And I don't have smog testing here. My inspection guy just pulls my car in to look like he's doing it and honks the horn then writes down my vin. I've known him for 10 years. He was passing my Suzuki with straight pipe from the turbo out. And sorry but I'm not an environmentalist. A little 1.6L isn't going to make much difference and I am not really open to discuss it. I don't like cats and don't really care to use them on a modded car. My audi is bone stock including the exhaust and that's what I drive most the time if that helps anyone sleep better.
