Differences between 1st and 2nd Generation MINIs
Discussion in 'MINI' started by Nathan, Oct 10, 2012.
    #1 Nathan, Oct 10, 2012
    Someone wrote to me today with the following question:
    I know some of them but don't them them all. So...I thought why not do the Web 2.0 thing and crowd source the question. After a period of time, say a week or so, compile the answers into an article for the Library.
    Lets take it beyond just the S too please. I've got a format in mind here too.
    Exterior
    2nd Gen has taller hood (bonnet) to meet EU Pedestrian safety laws
    2nd Gen Hood Scoop more ornamental than functional
    2nd Gen Wipers are now under the cowl
    2nd Gen Headlights are mounted in a Fixed position. 1st Gen are mounted in the Bonnet.
    2nd Gen Sunroof, both panes open.
    2nd Gen Scuttles in A Panel larger and easily changed (Full line of MINI and aftermarket versions available)
    1st Gen Front Grill continues into the front bumper
    2nd Gen front grille is fixed to the bumper, 1st Gen is fixed to the bonnet.
    2nd Gen Chrome /Black Taillight surrounds are thicker
    2nd gen C-pillar has a prominent vertical ridge, bottom to top,1st gen C-pillar is a smooth curve from the side window to the back.
    1st Gen rear side glass wraps around to rear.
    2nd Gen Belt Line Molding is wider
    2nd Gen has turn signals in the headlight housing, 1st Gen has them in the bumper
    Interior
    2nd Gen Speedometer even larger
    2nd Gen Battery moved to under hood (bonnet) on S models from rear
    2nd Gen right side upper dash contains a secret storage compartment. (left hand drive)
    2nd Gen Door Pocket are smaller
    2nd Gen seat-back release on top of seat-back, 1st Gen seat-back release on outside of lower seat
    Engine
    On S models 2nd Gen is turbocharged, 1st gen is supercharged
    On S models 2nd Gen has Direct Injection
    2nd Gen Oil Pan is stamped steel, 1st Gen is cast Aluminium
    Oil Drain Plug moved to bottom of pan on 2nd Gen
    2nd Gen Engine is a BMW/Peugeot design, 1st Gen is a Chrysler/BMW design
    2nd Gen Engines are made in the Hams Hall plant, in England, 1st Gen engines in Brazil
    On S models 2nd Gen has a front mounted intercooler, 1st gen has a top mounter intercooler
    2nd Gen has Intake manifold on back of engine, 1st gen has Intake manifold on front of engine
    2nd Gen has Exhaust manifold on front of engine, 1st gen has Exhaust manifold on back of engine
    Suspension
    2nd Gen Rear Control Arms changed to Aluminum
    Wheel Lugs changed to 14mm from 12mm on 2nd Gen (change was on 1st gen from July 06 builds on)
    Brakes
    2nd Gen has larger front rotors (same diameter as 1st Gen optional JCW Brake Kit)
    Misc
    2nd Gen uses a Fob and Start Button, 1st Gen has a key
    2nd Gen has a Sport Button, 1st Gen does not.
    Oh and Dave.0, this is not how is the 1st Gen so much better than the 2nd Gen. :D Just the differences please. We all know how you feel. As an aside...I am starting to fear the upcoming 3rd Generation MINI and the verbal sparring on how much better the 2nd Gen is but the 1st Gen was even the bestest evar.
  2. CHKMINI
    Exterior - 2nd Gen Headlights are mounted in a Fixed position. 1st Gen are mounted in the Bonnet.
    Interior - 2nd Gen right side upper dash contains a secret storage compartment.
    1st gen has large door pockets, 2nd gen has smaller ones
    1st gen has the battery in the boot, 2nd gen under the bonnet
    1st gen uses a key, 2nd gen uses a flying saucer
    1st gen uses an engine of Brazilian origin, 2nd gen gen uses an engine of French origin
    1st gen has a large central speedometer, 2nd gen has a huge central speedometer
    That's all I can think of now.
    I like both generations.
    [ame=http://www.youtube.com/watch?v=594WLzzb3JI]The Who - My Generation - YouTube[/ame]
  4. grodenglaive
    grodenglaive New Member
    Apr 3, 2010
    313
    68
    Ottawa, Ontario
    exterior visual cues to tell them apart at a glance:
    1st gen: front grill continues down the bumper
    2nd gen: thicker chrome surrounds on the tail lights.
    Exterior cues:
    1st gen C-pillar is a smooth curve from the side window to the back. 2nd gen C-pillar has a prominent vertical ridge, bottom to top.
    2nd gen skuttles are larger than 1st gen and extend at the front all the way to the front edge of ... whatever that panel is called.
  6. Dave.0
    1st Gen's are cool.:Thumbsup::lol:
  7. BlimeyCabrio
    1st gens sound like a Mini.
    2nd gens sound like a Subaru.
  8. docv
    docv Well-Known Member
    818
    280
    moble auto paint tech ( PTU )
    Central Missouri
    2nd Gen rear side glass does not wrap around
  9. Gil-galad
    Gil-galad Club Coordinator
    May 19, 2009
    1,178
    431
    Decorah, IA
    At least you tried... :arf:
    1st gen has a functional hood scoop
    2nd gen has a faux hood scoop
    2nd gen has a front mounted intercooler
  11. KittyMini
    KittyMini Club Coordinator
    1,183
    2nd Gen front grille is fixed to the bumper.
    1st Gen was fixed to the bonnet.
  12. CHKMINI
    Chrome beltline molding is wider on the 2nd Gen than the 1st Gen. (should be black anyway!)
    1st gen front turn signals in front bumper
    2nd gen front turn signals in headlight housings.
    1st gen seat-back release on outside of lower seat
    2nd gen seat-back release on top of seat-back... Nice improvement...
  15. Nathan
    All items listed up to this point have been worked into the first post.
    Lets keep them coming please.
  16. DneprDave
    Second generation MINI engines are not made in France, they are made in the Hams Hall plant, in England.
    MINI Plant Oxford - Home
    Dave
  17. Nathan
    Fixed..thanks for pointing that out.
    1st gen engines of American design built in Brazil
    2nd gen engines of French design built in Hammy Hall UK
    Fixed it more better.... :D
    1st gen engine has intake on front & exhaust on the rear
    2nd gen has exhaust on the front & intake on the rear
    1st gen engine has a cast aluminium sump
    2nd gen has a stamped steel sump
  20. mini_racer
    mini_racer Well-Known Member
    Engr Manager
    1st Gen is better!
    That pretty much sums it up.
