Brakes Wheels 2nd Gen Tires DIY brake help
Discussion in '2nd Generation: 2007+ R55 through R61' started by bloodhounds52004, Sep 13, 2012.
  1. bloodhounds52004
    bloodhounds52004 New Member
    Sep 13, 2012
    Do I have to replace the wear sensors when doing a 4 wheel brake job on my 08 Mini S?
    Thanks!
  2. Minidave
    4,592
    Did the light go on?
    If the sensor isn't worn thru and triggering the light, then you can reuse them, as long as you don't break them when you try and pull it out of the old pad.
    There are only two sensors, one in the left front and one in the right rear.
    However, if the light triggered on mileage rather than the wear sensor, maybe you don't even need pads - did you check how worn they are?
  3. bloodhounds52004
    Sep 13, 2012
    Minidave thanks, the light is on and the pads are worn. Its just my first brake job on the Mini trying to keep it simple.
