2nd Gen R55 Clubman Driver door won't open
Discussion in '2nd Generation: 2007+ R55 through R61' started by amataurus, Nov 27, 2013.
  1. amataurus
    amataurus New Member
    Nov 27, 2013
    Hi all, I am very new to the Mini world. I just purchased (through dealer exchange) a used '08 Clubman S.
    A few problems already :mad2:
    1. It seems the driver side door won't open - I have to push the handle/door in while simultaneously unlatching/pulling on door handle. (it opens just fine from the inside). Is there some fix I can do... Really not prepared to take it to the dealer.
    2. Only one key - should I order from new keys (One or two?) from the dealer or try ebay/online and reprogram myself?
    3. Sunroof won't open - just barely cracks but does not slide back. - it being winter, i'm not too concerned about this fix now.
    4. Reverse lights are not white - can I easily replace these on my own
    5. One fog light is out - any idea if I can do that on my own?
    .... no owners manual.... Ugh, I know i can get online version... but there is something about a real paper book that makes me feel better.
    I love the way it drives... going from a Chevy Avalanche to a Mini was a big change.
    Welcome to M/A the FUN Mini site. :Thumbsup:
    When you say you purchased through dealer exchange did you get any type of warranty?
  3. amataurus
    Nov 27, 2013
    No. Friend is a dealer and purchased the car for me.
  4. eMINIparts
    eMINIparts Well-Known Member
    3,751
    1,087
    MINI Parts Advisor
    Bedford NH
    Door latch , door lock cable , and outer handles are kind of common. The door latch can be getting stuck. Make sure the door is alligned correctly and not sagging.. Sunroof needs to be lubed , check the track make sure nothing is jammed.....There is only 1 reverse light on the Clubman...Should be a clear bulb....Fog light should have a access panel on the fender liner.........Take care of MINI and MINI will keep you smiling...:D
    If you tell us where you live someone may be able to direct you to a non-dealer MINI mechanic who can help.
  6. amataurus
    Nov 27, 2013
    Fairfax, VA
  7. minime331
    minime331 New Member
    Jan 27, 2012
    145
    30
    washington dc metro area
    Hey I'm in Fairfax va as well. Try posting a thread up on dcmetrominis.org we've god some good handy people also try c3m just across the Potomac. Also down in Manassas there is a shop called ptunning
