1st Gen 100K+ Driver side Window
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by MCS02, Sep 29, 2012.
  1. MCS02
    #1 MCS02, Sep 29, 2012
    Hi
    My 02 S left window has been making a clicking sound when you roll up the window. It would do it just before it got to the up position. Today it made a crunching sound and will only roll down a inch before hanging up. The cable in the front is loss and the one in the rear is tight.
    Can anyone help. Thanks.
    P.S. I'm also doing a carbon rap on the dash if anyone has some tips.
  2. AnsonIvan
    AnsonIvan Local Shop Owner
    Sep 25, 2012
    82
    MINI/BMW mechanic
    Columbus OH
    Time to order a new window regulator, it's not a bad job if you have a few tools.
    I believe 10mm socket, T20/30 a large set of channel lock pliers and a philips screw driver.
    Good writeup on Pelican: http://www.pelicanparts.com/techarticles/MINI/63-BODY-Window_Regulator_Replacement/63-BODY-Window_Regulator_Replacement.htm
    They recommend using a 5mm hex to remove the glass retainers, I use channel locks since it's tricky to fit a hex into that space and the retainers are typically very tight.
  3. MCS02
    Thanks for the help!
  4. MCS02
    Incase anyone needs a window regulator. Rockauto has them for $85.00
    You really have to watch the products from Rock Auto. Most of the time they are cheap Chinese knockoffs that won't last anywhere near as long as OEM, so what you save right now will be more than eaten by having to the job again and again.
  6. AnsonIvan
    Sep 25, 2012
    82
    MINI/BMW mechanic
    Columbus OH
    +1 for what Nathan is saying, I've tried several different aftermarket regulators on bmw's and minis and have encountered consistent early failure. The OEM regulators are the only way in my experience.
  7. eMINIparts
    eMINIparts Well-Known Member
    3,751
    1,087
    MINI Parts Advisor
    Bedford NH
    We have a discounted OEM Factory regulator available
    Link to the regulator:
    MINI Parts -
  8. MCS02
    The one I ordered has a 2 year warranty. so I thought I would give it a shot.
    You do have to watch what you get from them. I try to only order a part if its made by a known company. For instance I was looking at catalytic converter for a Honda. They have one made by MagnaFlow. Its not the cheapest but its still a good price.
    Your both correct and I should have included a warning
    Thanks Guys
