1st Gen R53 Cooper S Driving to work, clutch stopped engaging...
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by jasonixo, Nov 13, 2013.
  1. jasonixo
    jasonixo New Member
    Oct 24, 2011
    9
    Rifle Builder and Machinist
    Georgia, USA
    ... At least I made it to a parking lot, where I am typing this now. : )
    I shifted from 2nd to 3rd, and it was like shifting from 2nd to neutral- no acceleration, just revved up! I pressed the clutch in (pedal feels fine), shifted to 4th, and nada! Every gear acts like neutral.
    No bad noises, clutch feels fine. 90k trouble-free miles on this clutch (Lots of 6th gear highway miles) and no slipping or other clutch warnings. I'm idling here withy the heater running.
    Wife just pulled in- gotta get to work! Now to figure out a cheap way to get the car home....
    Thoughts?
  2. Metalman
    There is the possibility that the shift arm located on the transmission is defective. There is a pin that is swaged to the arm and have been known to loosen over time.... Some have simply welded this joint....
  3. jasonixo
    jasonixo New Member
    Oct 24, 2011
    9
    Georgia, USA
    The shifter still feels normal- crisp detents, nothing feels sloppy, it's not excessively easy or hard to shift gears. Are the shift detents in the shifter or transmission?
    The car feels like there is absolutely nothing wrong- the only thing that is off is that every gear acts like neutral. At idle, I can let the clutch out and hear a slightly different whirr in each gear like the ratios are doing their thing. There's just no go at the wheels. Uhoh... final drive?
    The moment before the car broke, everything was 100%. Then it was 0%. No slipping clutch or strange noises or weird feeling controls. There's still no strange noises even with something wrong-
  4. Dave.0
    Clutch slave cylinder could be leaking or failed. Can you not put it into gear now?
  5. AliceCooper
    AliceCooper Club Coordinator
    Mar 13, 2010
    643
    123
    CT Technologist
    South Florida
  6. jasonixo
    jasonixo New Member
    Oct 24, 2011
    9
    Georgia, USA
    Thanks for the advice- I don't think it is the cables, but I will check the trans-side this weekend- the shifter feels no different- it goes into and out of gear fine. clutch pedal feels fine as well. It's like there's no power getting to the wheels.
    This may sound funny but....
    You may have broken a CV joint. If you have your MINI will have no drive.
  8. jasonixo
    jasonixo New Member
    Oct 24, 2011
    9
    Georgia, USA
    Well, I have a clutch kit and everything in-between on the way... I put the car in the garage and got it off the ground in preparation for surgery.
    To address your suggestion Crashton, I put the car in-gear and tried turning one wheel while holding the other. It didn't turn- there is a solid connection through the (open) diff to the other wheel. I had some hope though! I also confirmed that my car unfortunately does not have an LSD. This would certainly be the right time to remedy that, but an LSD isn't in the parts budget... : (
    Sorry, was hoping it was relatively easy fix.
    Whose clutch kit did you buy?
  10. jasonixo
    jasonixo New Member
    Oct 24, 2011
    9
    Georgia, USA
    Kit from Pelican Parts- Luk 21-20-7-551-384-M37
  11. pops911
    pops911 New Member
    Aug 14, 2014
    #11 pops911, Aug 14, 2014
    which component was the culprit? same thing happening with my '02 mini cooper. thanks
    (update: mine turned out to be basic worn out clutch disk. the last bits fell apart all at once, and that's why it seemed to happen suddenly.)
  12. jeffster06
    jeffster06 Active Member
    Apr 23, 2010
    420
    111
    Dallas, GA
    When the car is off and you shift can you hear the mechanism working on the transmission? If it's in gear and the car is off can you push it as if you were in nuetral? It seems odd that the clutch would die with no warning. If you start the car in gear does it try to move? It could be possible that only one of the shift cables broke and it still give the feel that everything is ok with no odd noises or feel.
    Sorry for the blurb was just thinking out loud.
  13. jactommac
    jactommac New Member
    Sep 5, 2016
    Okay, sorry to revive a dead post but my wife's car now has the same symptoms. what ended up being the problem part?
  14. Friskie
    Friskie Well-Known Member
    Jul 20, 2009
    1,650
    1,333
    Highly motivated retiree
    In the here and now, for now.
    Don't hold your breath, the OP's last post was near 3 years ago and he'd only made 9 postings then. You might try PM but I doubt seriously he is even visiting NAM anymore.
  15. Guapish_Fliver
    Guapish_Fliver New Member
    May 31, 2016
    272
    Pimpin
    Da wess
    Did u try bleeding it?
  16. beken
    beken Well-Known Member
    Jan 13, 2010
    1,405
    1,829
    Delta, BC
    A few years ago, I replaced my clutch and was driving out of the office parking lot and I heard a bang and my car was in neutral even though my transmission was in gear. any gear.
    After being warned that if there was nothing wrong with the clutch, I would have to pay for the labor of putting my car into service mode, it was found that the teeth in the bearing that holds the clutch plate to the transaxle drive shaft had stripped. Being as it was a new clutch plate, the whole thing was covered under warranty. Luckily, there was no damage to the transaxle shaft. Just the clutch plate bearing. In fact, the clutch plate friction surface still looked brand new. I was complimented on how smooth I drove.
    If you have never had your clutch changed since the beginning, it's probably time anyways. Clutches are wear and tear items.
    The job is expensive. 8 hours of labor.
    While it was all opened up, I replaced the flywheel also. For 1/2 the price of a new dual mass flywheel, you can buy a full Valeo single mass flywheel and clutch conversion kit. It doesn't grab quite as hard as the stock dual mass flywheel clutch set up, but it is much simpler and far more reliable set up.
