1st Gen R53 Cooper S DSC Light coming on at redline
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by anuppercasej, Dec 10, 2015.
  1. anuppercasej
    anuppercasej New Member
    Jun 11, 2010
    185
    38
    Portland, OR
    I have had this happen to me a few times recently while driving my 2006 R53. Under very spirited acceleration, getting near redline, the DSC light will turn on. Once it turns on it stays on until I shut off the car and it doesn't come back on after restart. I've even reset the ECU and it still happens. Current mods are a 15% pulley, Craven CAI, and a WMW Quicktune, I'm currently at 91k miles. I'm curious as to what is causing this and if it is something I need to worry about.
    I did a search to see what info I could find and it came up with a thread on the other site, but there wasn't a whole lot of info. Anybody have any ideas?
    Any codes?
  3. anuppercasej
    Jun 11, 2010
    185
    38
    Portland, OR
    I haven't put a code reader on it, I should probably do that. I just assumed if there wasn't a CEL there might not be a code. I'll check it tonight.
  4. anuppercasej
    Jun 11, 2010
    185
    38
    Portland, OR
    I did a fault code check Torque Pro and it said there were no stored codes in the ECU. Maybe I should try to get the light to turn on then check for codes again.
  5. Dave.0
    Just turn off DSC or buy better tire's that can grip the road very well.
    Your is loosing grip and the computer is taking over and turning the DSC on.
    You are after all pushing your car to redline and if you are running Runflats or a cheaper tire in cool weather conditions this is typical.
    Your need for speed is exceeding your tire's limits in th urgent temps.
  6. anuppercasej
    Jun 11, 2010
    185
    38
    Portland, OR
    Could certainly be a possibility since the cold wet weather has arrived here in the Pacific Northwest. I'm planning on replacing the tires very soon. These ones were on the car when I bought it, even though they are fairly new, I haven't been impressed with them. I can easily spin the tires any time I start from a stop.
    Kill the nanny...... :D
  8. narvarr
    narvarr Active Member
    Nov 8, 2014
    183
    116
    Maintenance Tech
    Rowlett, Tx (Dallas Metro)
    Usually, the DSC light will come on and stay on if you have an overboost condition or if your TMAP sensor is flaking out. How high does your boost get at redline?
  9. UKCoopeR
    UKCoopeR Active Member
    May 21, 2009
    293
    109
    VA,USA and UK
    #9 UKCoopeR, Dec 25, 2015
    What this dude said ^
    I had that happen to me but i also threw codes which made trouble shooting easier... (ending up being one of the map sensors, don't remember which one). Replaced the sensor and everything was back to normal. Does it idle okay? Mine starting stalling at idle after a day (took a while to get the part)
  10. anuppercasej
    Jun 11, 2010
    185
    38
    Portland, OR
    I think of seen around 16-16.5 psi at boost at other times when I have been monitoring it. I don't know what I was getting when the light came on. Idle, for the most part, seems fine, no stalling issues. I'll look into the TMAP sensor, it may be good to replace it just in case.
  11. narvarr
    Nov 8, 2014
    183
    116
    Maintenance Tech
    Make sure to get an OEM or equivalent. I got one from a local parts house and it lasted all of 6 months before it died. Replaced with OEM and all is good.
  12. anuppercasej
    Jun 11, 2010
    185
    38
    Portland, OR
    Cool. I will track one down.
