1st Gen R53 Cooper S E85
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by CurrysMini, May 29, 2011.
  1. Guest - Welcome to the new Motoring Alliance Site! Steve, MCS02 and I were up until the early hours this morning working to get it done... as you can see it took us a bit longer than expected to get Phase 1 up and running. We are not 100% there.. its a journey. For site updates, "How Do I" and feedback please use the Announcements, How Do I, Feedback Forum (Links below). Like building a car.... its never done... and thanks for your patience
    Site Announcements "How Do I" Feedback
  1. CurrysMini
    CurrysMini New Member
    Mar 14, 2011
    27
    Corpus Christi, Texas
    What all do you need to change out to run E85 on a R53 and is it worth it for cost and power?
  2. CurrysMini
    Mar 14, 2011
    27
    9,989
    Mynes has been working in that area. I'm fairly certain after the holiday weekend if not that Mike will chime in.
  4. mike@MynesTuned
    mike@MynesTuned New Member
    May 16, 2009
    286
    I posted a reply earlier, but somehow it 'disappeared' :(
    Base on our testing, the following would be required:
    1. Bigger injectors (we use the Bosch OE 550s)
    2. Proper mapping (need the proper scaling for the 550s for E85)
    3. AFR Kit to display AFR so you can use it for tuning and also during the map-switching process.
    There is a complete solution here:
    http://www.motoringalliance.com/forums/bytetronik-tuning-discussion/5573-bytetronik-miniflash-fullaccess-tuning-kit-pricing-package-deals.html
    Feel free to contact me for more info or details.
  5. CurrysMini
    Mar 14, 2011
    27
    I already have the Bosch 550s and I have already had you tune it, but obviously not running E85. Whats the pros and cons of using E85? And how does the flash kit work exactuly? Sorry for all the questions Mike. Still trying to learn. :)
  6. mike@MynesTuned
    May 16, 2009
    286
    The pro's of running E85 is higher octane rating = +25 to 30 WHP / +15 to 20 WTQ.
    The con's:
    - E85 requires 30% more fuel so the extra HP will come at a lower MPG
    - E85 is corrosive and may cause failures in the fuel delivery system.
    More info on: E85 Benefits and Drawbacks | Advance Auto Parts
    The Tuning Kit will allow you to load maps as well as editing maps. It also provides data-logging and "adaptation clearing" (which is critical when you switch fuel types). Previous Mynes Customers get a discount on the Tuning Kit, and we can provide a 'base E85 map' for your car.
    We have been running E85 "ON and OFF" for the past two years without any issues. When we did the TPR1 head upgrade, we took a peak inside the cylinders and they looked squeaky clean - no carbon build up whatsoever. Please remember, YMMV and understand that there are risks in running E85.
  7. CurrysMini
    Mar 14, 2011
    27
    If I start running E85, and I'm out on the road and need gas and E85 isn't around can I still use 91 Octane? Also if I do more mods to the car does the tunning kit take care of those or do I need it customed tunned again? Sorry if these question seem elementary:confused5:
    And what kind of discount to you give previous customers?
    Thanks for all the info Mike I really appreciate it. :thumbsup:
  8. mike@MynesTuned
    May 16, 2009
    286
    NP. Here are some clarification. The tuning kit will enable you access to the maps so you can take it to any local tuner so they can fine tune it for you.
    If you run out of E85 and don't have a station near by, you can put 91 or 93 octane back in the tanks, then keep an eye on the AFR. As the 91/93 start to mix in and the E85 starts burn out, you will see the AFR start to go lean. So it's best to run at lower rpm and take it easy as the pump gas starts to blend in and take over... then you'll load the 91 map back in - the flashing of the new map only takes 45 seconds to complete (pull the car over first, of course), clear "All adaptations", then start the car and go your merry way.
    Previous customer get a $200 discount towards the Tuning Kit. There are various blends of E85 so the E85 that we have in Cali might not be as good as the ones in Texas (or vise versa).
  9. CurrysMini
    Mar 14, 2011
    27
    I'll have to do some checking around to see about close gas stations that carry E85. I think there is only one close. Plus I don't know of a local tuner. So it will have to be a weekend trip to Houston. Thanks for all the info Mike. Just ordered some Wilwoods last week, so have to wait a little bit for the tuning kit. Wife gets a little upset when the UPS guy comes to often...
  10. Desy232
    Desy232 Banned
    Dec 4, 2017
    10
    Hi, I happened to see the topic. This is what I was looking for
  11. Canusrufis
    Canusrufis RMW Powered R53
    182
    67
    Winston Salem NC
    Jan Brueggemann @RMW has developed a number of E85 "safe" parts including fuel rail, pump, etc. After a bottom end rebuild I'm going that route.
