Pre Migration Editing quoted text.
Discussion in 'Announcements, How do I, Feedback' started by goaljnky, May 17, 2010.
  1. goaljnky
    3,105
    394
    Folks,
    Since I see some people do it at time, I want to through this out for everyone to keep in mind:
    When quoting other people's posts it is considered bad netiquette to edit the quoted text. As I understand that sometimes you want to draw attention to only a particular part of the quoted post here are some suggestions:
    1. Remove all parts that don't apply and replace removed text with 3 periods. Example:
    2. Just bold the section that you think is relevant. Example:
    Thank you,
    The management.
  2. Minidave
    I do it so that the reader doesn't have to read the entire quote, I'll use the three dots method from here on out if you prefer.....
  3. lotsie
    stagehand/part time detailer
    Right here
    I promise to ... from now on.
    I would like it if someone quotes a post with lots of pictures, they don't included all the photos, makes for real long pages.
    Mark
  4. goaljnky
    3,105
    394
    We can run that by Nate. He might be able to handle that in software.
  5. goaljnky
    3,105
    394
    My suggestions, or your own are fine. Just when I see text added, or removed selectively without warning in a way that changes meaning, or HUGE fonts... it gets my old usenet hackles up.
  6. Nathan
    I'm looking, but can only find a very old mod from 2005 that has been archived and is no longer available. Also found a thread on the vBulletin support site that asked the very same question. The vBulletin Customer Support Manager simply replied "There is no automatic way to do that. "
    The search continues, may have to try and write this myself.
  7. goaljnky
    3,105
    394
    How about if quoted text contains more than 2 Img tags, ask user to confirm?
  8. Rixter
    Rixter Well-Known Member
    Jun 14, 2009
    1,230
    79
    Technology Architect
    North of the 49th
    I certainly don't want to practise bad netiquette. That sounds worse than learning Engrish :D
  9. goaljnky
    3,105
    394
    You meant like learning Engrish in Alizona?
  10. Rixter
    Jun 14, 2009
    1,230
    79
    North of the 49th
    Exactry :crazy:
  11. nabeshin
    nabeshin New Member
    Jun 8, 2009
    409
    Lincoln, NE
    The worst I'd do is correct spelling errors when quoting. Other than that I'd bold or use the ...'s.
