Electrical Engineer? Got a question for you
Discussion in 'General Chat' started by Nathan, Nov 11, 2015.
    Can I use a product such as DeoxIT on an iPhone's charging port? I've always only used it on audio components.
  2. Minidave
    4,599
    It will clean any corrosion off the contacts, for sure.....if you use it sparingly I can't think of anything it would hurt.....
    Thanks, I've been having troubles with charging no matter which of the myriad of cables I've used. Cleaning the port looks to have been fixed.
  4. MCS02
    6,278
    Some times lint gets in my charging port. I use a paper clip to lean it out.
  5. mrntd
    Indented connections are the hardest to get corrosion off. Your solution is the best for that. On connections that are exposed I just use an eraser.
  6. BruceK
    BruceK Active Member
    Feb 24, 2015
    Texas
    I used a broken toothpick for the same purpose. The rough broken edge catches the lint particles great and since it is wood there are no worries about scratching any metallic connectors.
  7. Zapski
  8. minirab
    Kind of like with a belly button?!:D
