2nd Gen R55 Clubman Engine knock
Discussion in '2nd Generation: 2007+ R55 through R61' started by mikekellyvab, Aug 29, 2016.
  1. mikekellyvab
    mikekellyvab New Member
    Aug 29, 2016
    22
    Just bought an 09 mini s. I hear this engine knock. Not the ticking but the knocking sound. Any ideas?https://vimeo.com/180669401
  2. Metalman
    Timing chain / chain tensioner issue...
    Don't drive it.... Have it towed to the dealer....
    No really.... Don't drive it...
  3. mikekellyvab
    Aug 29, 2016
    22
    Are you 100 percent positive .
  4. Guapish_Fliver
    Guapish_Fliver New Member
    May 31, 2016
    272
    Pimpin
    Da wess
    I don't think it's so bad it's going to crash valves on the way to the dealer lol. Mine sounded like that once.
    Might not be such a bad thing if it did. What's the mileage? You'll prolly fit into the class action... Just leave it, drive the piss out of it until it splodes, then get yeh a new motor breh.
    Otherwise just throw the longer tensioner in there first ($30). If that doesn't fix it then get a chain and guide kit.
  5. mikekellyvab
    Aug 29, 2016
    22
    105, 000 miles, was driven for 3 hours from where we bought to our home .
  6. Guapish_Fliver
    May 31, 2016
    272
    Pimpin
    Da wess
    I drove 4 states like that after I bought mine :cornut:
    The tensioner ended up being the least of my woes
  7. mikekellyvab
    Aug 29, 2016
    22
    Anything happened? You ever get it fixed?
  8. Metalman
    I would go with my suggertion...
  9. Guapish_Fliver
    May 31, 2016
    272
    Pimpin
    Da wess
    The longer tensioner fixed mine... I peeped the guides when I did my valve cover and they were fine. Looked like they were done before..
    The engine had a line of other issues and I opted to replace the chain as a preventative measure while the engine was apart in case it stretched.
    You'll prolly be fine with the tensioner it's a 10 minute job. Check the vids on YouTube
  10. mikekellyvab
    Aug 29, 2016
    22
    How hard is it to replace. I've never worked on mini. Only nissans
  11. Guapish_Fliver
    May 31, 2016
    272
    Pimpin
    Da wess
  12. mikekellyvab
    Aug 29, 2016
    22
    Thank tou
  13. 00Mini
    2,227
    Welcome to Motoring Alliance and good luck with your repairs !!
  14. mikekellyvab
    Aug 29, 2016
    22
    Thank you for the greeting
  15. wmwny
    4,048
    2,246
    Welcome to M/A!:Thumbsup:
  16. MCS02
    I would listen to metalman. Don't drive it till you fix it. How good are you at doing your own work? If you have the skills to work on the engine of your car then you can probably do it yourself. If not take it to the dealer.
  17. Dave.0
    ^^^^ See this? ^^^^^
    DO IT !
  18. Goldsmithy
    Jan 30, 2015
    1,748
    982
    TCB
    Main Street in the land of Oz
    Welcome to MA...great site and greater people. I'm not a mechanic, don't even play one on the internet, but I wish you a lot of luck with your engine.
  19. mikekellyvab
    Aug 29, 2016
    22
    Y'all mini owners are pretty cool. Definitely different from the Nissan forums in a good way!
  20. Grizld700
    Grizld700 Well-Known Member
    Feb 2, 2016
    1,212
    47
    Eastern Iowa
