Engine Drivetrain 2nd Gen S Engine light coming on..
Discussion in 'Tuning and Performance' started by gmodder, Feb 13, 2011.
  1. gmodder
    gmodder New Member
    Sep 25, 2010
    16
    Technician
    Willis,Texas
    #1 gmodder, Feb 13, 2011
    I have a 2011 club s with 4000miles on it. This afternoon when i started the car i got a Light on the tach with a engine symbol...It wont go away unless i push the button on the blinker controller....Now i have done some mods to the car like the DOS Cai and the way motor works performance blow off valve..here is the link
    WMW Performance Blow off Valve - Way Motor Works
    But both parts have been in the car for over 400miles now...
    I was just wondering if anyone else has got this light on there cars and what it ended up being...
    I guess i didnt explain the light very well...But its in Yellow of course and it looks like a engine block..with half of the inside of it colored in...
  2. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    Not alot of details to go on here. First comes to mind is that it will probably go away. 2nd is that it is under warranty, take it in if it doesn't go away
    Overall good idea to get yourself of OBDII reader
    Knowing the codes would help a lot. A local Autozone would be helpful in reading codes or if you tell us where you live maybe a fellow M/A member can assist in the code reading.
  4. gmodder
    gmodder New Member
    Sep 25, 2010
    16
    Technician
    Willis,Texas
    Thanks for the responses..Sorry i dont have any other details. car was fine when i parked it lastnight....I updated my sig..
  5. sirhc
    sirhc New Member
    Feb 11, 2011
    oklahoma city,ok
    i would have a local autoparts store scan before you take it to the dealer, if they decide that one of your aftermarket parts is the culprit then it can cause you some serious problems later down the road. you can get a generic obd2 scanner for $40-60 i strongly suggest it
  6. Mini'mon
    Mini'mon New Member
    Jul 16, 2009
    142
    39
    MINI Performance Parts Designer
    San Francisco, CA
    The only codes that we've seen from the DoS CAI are from when a customer gets a little too enthusiastic with the K&N recharger oil after cleaning our filter element, but this is easily remedied. Considering that you only have 400 miles on the parts, you probably have not cleaned your filter yet (at least I hope not).
    Definitely let us know the codes once you've plugged-in a scanner to your OBDII port. The M/A community and DoS wants you code-free. :Thumbsup:
    -Clint
  7. gmodder
    gmodder New Member
    Sep 25, 2010
    16
    Technician
    Willis,Texas
    #7 gmodder, Feb 14, 2011
    Well just got back from the dealer...And they said it was a Intake sensor that went off..So of course they blamed the CAI....They said they saw nothing wrong with the car and dont really know why it through a code..Except the Aftermarket Cai.....So we will see if it throws another code..
    Hey got the codes..Here they are Exactly worded on Dealer work order
    29DC AND 2C58 stored in DME for charge air temp sensor Plausibility.
    Aftermarket Intake System installed. Possible cause of fault is key cycled during installation of intake system causing faults to occur. At this time faults were cleared.
    Did they tell you what the code was?
  9. Mini'mon
    Mini'mon New Member
    Jul 16, 2009
    142
    39
    San Francisco, CA
    Did the dealer give you the actual numerical code that they read off their scanner? Was it P115C?
  10. Mini'mon
    Mini'mon New Member
    Jul 16, 2009
    142
    39
    San Francisco, CA
    Ahh . . . BMW Codes, not "P" codes.
    29DC = Cylinder injection switch-off: Short circuit or signal interruption
    2C58 = Charge-air pressure control, deactivation: charge-air pressure buildup disabled
    These codes are fuel system and charge air pressure control/regulation problems downstream of your CAI. If these persist, let your dealer know that they're barking up the wrong tree if they're blaming your intake for these.
    Best,
    -Clint
  11. gmodder
    gmodder New Member
    Sep 25, 2010
    16
    Technician
    Willis,Texas
    The way BOV valve couldnt cause this either could it???
  12. sirhc
    sirhc New Member
    Feb 11, 2011
    oklahoma city,ok
    it could but you said you had it on there for a little while so probobly not. just double check you connections make sure everything is A-OK and see if it comes back
  13. gmodder
    gmodder New Member
    Sep 25, 2010
    16
    Technician
    Willis,Texas
    And thats like talking to a wall sometimes...
  14. Mini'mon
    Mini'mon New Member
    Jul 16, 2009
    142
    39
    San Francisco, CA
    :mad2:If you go in there not understanding what your service advisor is talking to you about, that can be the case.:mad2:
    An inexpensive code reader is an important tool to have -- especially once you start modding. It can save you loads of time and trouble at the dealer.
    Best,
    -Clint
  15. minimark
    .....rip a 20% off Harbour Freight coupon out of a magazine and run down and get one. They don't have the exact BMW codes but they can give you enough info to head you in the right direction. 2cents
  16. ColinGreene
    ColinGreene Well-Known Member
    438
    293
    Orange county Ca
    Harbor freight, No way. The Chineese already own a ton of our debt why give them our money to boot!
  17. gmodder
    gmodder New Member
    Sep 25, 2010
    16
    Technician
    Willis,Texas
    Thanks for all the help...I will get the gauge yall recommend....Funny thing is i use to have a scangauge in my 08 clubman but i have lost it somewhere....:cryin:
  18. durkART
    durkART New Member
    Jul 25, 2011
    Self
    Orlando Florida USA
    #18 durkART, Jul 25, 2011
    At the mini dealer again for the second time. Again check engine light on-fuel pump. I bought the car 2 weeks ago-New. Dealership said they reset it last week-something MUST be wrong. The dealership is so nice, apologist. I'll post the outcome.
  19. durkART
    durkART New Member
    Jul 25, 2011
    Self
    Orlando Florida USA
    Mini repaired it and a week later happened again
    3 weeks I bought a brand new mini clubman in the service center 3 times AAAAAUUUUGGGG!!!! I'll be there at the service center 8 am AND I better get some answers!!!!
