1st Gen R53 Cooper S Engine Sounds
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by GeorgeCo, Nov 9, 2009.
  1. GeorgeCo
    GeorgeCo Site Sponsor
    Motoring Alliance Sponsor Supporting Member
    Oct 29, 2009
    253
    38
    Motorer
    Mt. Airy, MD
    Anybody recognize this sound?
    http://www.georgeco.org/audio/MINIsound.mov
    2004 MCS w/120K miles. Original PS Pump, fan and tensioner pulley. Recorded w/car at idle after 10 minutes, heater blower off, not turning the steering wheel. Not the engine fan. Not a barn owl. Not stanley steamer...
    Any ideas?
    Holy crap, that's a new one on me! That's really coming from your MINI? Weird.
    Well, I'm obviously no help. Here's hoping one of our many experienced types will chime in.
    Good luck and welcome to M/A!
  3. Metalman
    A cold start MINI at a train crossing?:frown2:
    Wow, very strange.
  4. BlimeyCabrio
    That car is possessed. Yikes.
  5. mini_racer
    mini_racer Well-Known Member
    Engr Manager
    That aint right! And hard to believe it is an automotive sound, very strange.
  6. demons took over it. car was crying in the beginning of the clip.
  7. Deviant
    Deviant Banned
    Student
    Southern IL
    Isn't that what Blimey's horn sounds like?
    That or you have a harmonica stuck in your intake. Can you pinpoint where on the engine it's coming from?
  8. ScottinBend
    PCV valve? Had a car that made some very weird sounds and it ended up being a plugged PCV valve. It caused some pressure in the valve cover and it was escaping around the oil filler cap.
  9. GeorgeCo
    Oct 29, 2009
    253
    38
    Motorer
    Mt. Airy, MD
    I like the sound of that (pun intended). That sounds like something I can fix. Where do I look for it? If I loosen the oil filler cap a little when I hear it I guess that would check your theory, no?
  10. BlimeyCabrio
    Sounds like a good test.
    This has got me thinking... I don't know when (if ever) my PCV has been replaced. Just ordered one.
    The PCV is the thing plugged into the passenger side top of the valve cover - connected to the rubber hose. #1 in the pic:
  11. GeorgeCo
    Oct 29, 2009
    253
    38
    Motorer
    Mt. Airy, MD
    #11 GeorgeCo, Nov 11, 2009
    Rats. Replaced the Valve and that's not the source. It's hard to figure out where exactly it's coming from -- the fact that it's raining and I'm standing with my head in the engine compartment as the rain fills my ears isn't helping either. It really sounds like steam blowing off, like some sort of pressure relief valve. I think on the back side of the engine. I checked the fluid reservoir and I have enough coolant. I put a towel around the cap as the sound was being made and the pitch didn't change. After I replaced the PCV Valve I checked the hose and there's a good vacuum there. Power steering fluid is good and the pitch of the sound didn't change when I opened the PS reservoir a crack. I'm stumped.
  12. nabeshin
    nabeshin New Member
    Jun 8, 2009
    409
    Lincoln, NE
    So the car runs fine besides this noise? I'd get a mechanic's stethoscope and start poking around.
    I second the mechanic's stethoscope advice. You can get one pretty cheap (less than $20) and you'll likely find more reasons to use it over the years.
  14. BlimeyCabrio
    They were on sale for $4 at harbor freight last week - might still be on sale...
  15. imspencerwithanr53
    imspencerwithanr53 New Member
    May 27, 2009
    117
    Barista
    Portland, OR
    How's your Oil level? I would do an Oil Change right away. See if there are any metal shavings in the oil. My car was making that sound last week and I changed my oil to check for shavings. But the the oil change fixed the sound.
    If it doesn't change the sound... Pull the valve cover again and check for a bad lifter. It could be possible that a lifter clip broke and you might have to replace it. It's under $100 from the dealer... So i've heard.
  16. GeorgeCo
    Oct 29, 2009
    253
    38
    Motorer
    Mt. Airy, MD
    Interesting. Oil level is good, but it's about time to change. I'll give it a try. Thanks.
  17. nabeshin
    nabeshin New Member
    Jun 8, 2009
    409
    Lincoln, NE
    Did you get a chance to change it? Did it work?
  18. GeorgeCo
    Oct 29, 2009
    253
    38
    Motorer
    Mt. Airy, MD
    Changed the oil today. Ran car on ramps afterwards to check for leaks. Once good and warm, PS fan kicks on: woo-hoo, hoo-hoo. Turned off the car, turned key so the fan came on. That's it.
  19. ScottinBend
    So...the bearings are going out? Time for a new fan?
