2nd Gen R56 Cooper Engine swap, n16 into n12 car
Discussion in '2nd Generation: 2007+ R55 through R61' started by MrBlah, Jul 25, 2017.
  1. MrBlah
    MrBlah Member
    Jun 19, 2015
    114
    anyone done this? I've been going through the part numbers and I've only found a couple differences, head same, belts/pumps/thermostat same, sensors same, intake/exhaust same, timing chain setup the same (who said n16 was more reliable?!?!)
    block, oil pump and oil filter housing changed but that's all I've found so far
    I picked up a 09 justa with a blown motor, n16's are 400-600 $ cheaper than n12's
    Do you mean N14 and N18? I would stick with the N14. It is a very strong motor it just has a bad rap from the way the PVC system is routed.
  3. rkw
    rkw Well-Known Member
    443
    No, he is talking about N12 and N16 engines of the non-S Cooper.
