Engine Drivetrain 1st Gen Cooper S facelift cruise control retrofit
Discussion in 'Tuning and Performance' started by MrBlah, Oct 3, 2016.
  1. MrBlah
    MrBlah Member
    Jun 19, 2015
    114
    anyone else retrofit cruise control on a facelift r53?
    I ran into a problem with pin 101 on the ECU harness, it's already occupied by something else
    maybe i counted wrong, O will check again tonight, the Fuse box pin was also occupied already but I'm going to just use the existing clutch switch once I verify it's voltage output.
    I think the installation pdf is made for a pre-facelift car, I've not had any luck finding an install pdf for a facelifted R53.
  2. GokartPilot
    GokartPilot Well-Known Member
    Jan 9, 2012
    967
    727
    training specialist
    Maysville, North Carolina USA
    What is a facelifted R53? :confused:
  3. 00Mini
    2,227
    I believe first generation cars made from July 2004.
  4. GokartPilot
    Jan 9, 2012
    967
    727
    training specialist
  5. MrBlah
    MrBlah Member
    Jun 19, 2015
    114
    yeah, they changed quite a bit for the "facelift" 2005/2006, everything from transmission gearing & exhaust hangers to the dash. And it seems the clutch switch, clutch switch wiring, fusebox wiring, ecu wiring.
    Thankfully realoem makes it easy to ensure you get the right part, but it does not help with retrofit instructions only for the early cars
  6. MCS02
    Wish I could help but you over my head.
  7. ZippyNH
    We have lots of smart azzes here....
    Think most if us saw your thread over on "the other site"...
  8. Metalman
    Bentley manual with the electrical schematic might be of some help....
  9. MrBlah
    MrBlah Member
    Jun 19, 2015
    114
  10. ZippyNH
    I remember that back before "face-lift" cars, dealers DID do retrofit's...was lots of work, but doable.
    But after they came out, they stopped, and told folks to re-order or buy a different car....
    Perhaps it was due to more than just a change in difficulty or time and $$ involved....
    Been a longtime....but thinking back to 2003/4 when I was thinking of buying, then ordered in 2004....and got a 2005....just how I remember it.
  11. MrBlah
    MrBlah Member
    Jun 19, 2015
    114
    time wise it's not very bad, remove dash lay wires, plug into connectors already there behind center speedo, fusebox, clutch switch and over at the body module
    mine is done except for ecu, waiting on a couple guys that did facelifts already to respond
  12. MrBlah
    MrBlah Member
    Jun 19, 2015
    114
    ista/p has a retrofit function for cruise control, it shows as an installed option on my car now (also retrofit computer so I can see mpg now) but I still have not got mine to work next step is troubleshooting the buttons & clockspring.
    inpa wont let me test the mfsw says module not installed, I recoded kombi, gm, and ecu after I did the retrofit, not sure what else it could be other than bad wiring
