fault code interpretation
Discussion in 'Starting Line - New Member Introductions' started by Angelajp, Jul 31, 2017.
  1. Angelajp
    Angelajp New Member
    Jul 31, 2017
    Hello i just pulled fault codes from a carly adapter. These codes do not correspond with any lists i can find. Where do i find them? Carly has listed codes 00301E, 002B64, and 00A0A9. If someone can answer any, it would be appreciated. i'm 3 hours away from the closest dealer and had bad luck with local mechanics.
  3. Angelajp
    Angelajp New Member
    Jul 31, 2017
    Thank you! I have. 2008 Mini Cooper S Gen 2. I have seen those codes on the link but they look nothing like mine. I feel like I'm missing my secret decoder pin to decipher.
  4. MCS02
    Those don't match any codes in the Bentley manual so I am no help, sorry. What is the problem with the car?
  5. cristo
    cristo Well-Known Member
    Jan 4, 2015
    5,713
    924
    physician
    York, Pa
    I'm guessing you need buy the full Pro Version app to
    get information on the Carly versions of the OBD codes.
  6. Dave.0
    Oh you have a 2nd Gen, it's a carbon build up issue. :p
    Just keep driving until you get to a dealership.
  7. Angelajp
    Angelajp New Member
    Jul 31, 2017
    It acts as if it has a battery, electrical issue, or a computer issue. It has a new battery. I get sporadic clicking noises at start up and my lights showing that certain features are disabled. After driving and turning off the motor a few times it will return to normal.
    I also just noticed the back lights come on when I lock the car even when the lights are in the off position.
    I have purchased single licenses through Carly. I recently found out that I need to register the battery which I plan to do but now I'm skeptical that Carly isn't working for me and they have not responded to my questions.
  8. MCS02
    Try a different code reader. Just go to a parts store and have them read the codes and see what you find. I think Carly will register a battery.
